September 17, 2026, 05:39:01 am
Hoffman Amps Forum image Author Topic: Fender AB763 Twin Reverb Boards  (Read 15156 times)
Offline bnwitt
  • Crankin' out the tone.
« on: May 04, 2009, 01:09:13 pm »
Since I am black facing the 135 Watt Twin Reverb I did my normal board layout drawings.  So, I thought I would share the boards with anyone who might be interested.  I'll share the whole wiring layout when it is done.  These boards can be used to build a black face twin reverb or Super Reverb etc.
Barry
« Last Edit: May 04, 2009, 06:46:49 pm by bnwitt »
Offline Danskman
Re: Fender AB763 Twin Reverb Boards
« Reply #1 on: May 04, 2009, 02:40:22 pm »
Very nice work! Thanks for sharing it! What software are U using to draw this?
regards,
Danskman
Offline bnwitt
« Reply #2 on: May 04, 2009, 02:44:03 pm »
Microsoft Visio 2003
Offline jasperok
« Reply #3 on: May 04, 2009, 03:34:11 pm »
such nice layouts
btw do you have to switch the OT when using this layout or could one use he stock UL transformer?
Offline bnwitt
« Reply #4 on: May 04, 2009, 03:40:29 pm »
If you are talking about the Silver Faced 135 Watt Twin Reverb, you could probably use the OT and just drop the UL connections, (somebody correct me if I'm wrong) but you have to change the PT
« Last Edit: May 04, 2009, 03:43:09 pm by bnwitt »
Offline bnwitt
« Reply #5 on: May 05, 2009, 09:44:31 am »
Here is a version of the boards with the PI output components altered for a post phase inverter master volume which I will be using in this build.  Not much different, just a couple of additional coupling caps and terminals.  This is the master volume that uses the double stacked 1meg audio pots.
« Last Edit: May 05, 2009, 11:43:43 am by bnwitt »
Offline PJBayer
« Reply #6 on: October 02, 2010, 12:44:25 pm »
Beautiful work. Any chance you'd send out the Visio diagram so I could modify to reflect my layout?
Offline joepirroni@rcn.com
« Reply #7 on: March 03, 2014, 07:33:52 pm »
can someone tell  me where to download a ab763 one channel schematic
I want to build a ab763 one channel deluxe reverb
« Reply #8 on: March 03, 2014, 07:44:09 pm »
Which channel?
