September 24, 2026, 06:19:10 pm
Hoffman Amps Forum image Author Topic: Using X-Y plot on a scope  (Read 6346 times)
Offline tubesornothing
« on: June 12, 2009, 09:58:43 am »
PRR mentioned using X-Y plot on a scope.  I have never used this, but would LOVE to see where and how I can use it with amp building.
Basically I am looking for an excuse to use my scope for something, anything.  I love scopes almost as much as playing the geetar.
Offline mackie2
  • "Follow The Red Wire"
Re: Using X-Y plot on a scope
« Reply #1 on: June 12, 2009, 04:34:36 pm »
Tubesornothing--
Steve  Bench  tube site  (http://greygum.net/sbench/sbench102/caps.html) has a series of capacitor tests using X-Y scope  examples with explanations.
Other useful tests  may include testing Inductors, Transformers diodes, etc.
Also sweep gen representations of Amp  Frequency  Response,  can be shown on the scope two ways: 1) vertical  amplitude displaying frequency and amplitude of the amp under test, or 2)   The X-Y  sweep Gen Scope Method, will generate a curve  of amp's frequency response.  However, most amp players and  Techs  Depend on the ear.
Ham Radio People find a lot of use for the X-Y scope use. Tektronix  570 Curve tracer for vacuum tubes--uses the  X-Y mode  to trace individual Tube Curves designed in the unit
Mackie2.
1/2 a Valve is better than no Valve at all.
« Reply #2 on: June 12, 2009, 08:28:03 pm »
Perhaps the best use:
Feed the input of an amp (complete or one-stage) to 'scope H-input, feed the amp output to 'scope V-input.
Apply variable signal.
If the amp is "perfect" (constant gain at any input level), you get a slanted straight line.
No amp is perfect to infinite signal. And the way it gives-up at high signal is the way we add emphasis to the thin sound of a naked steel string.
It is too muggy tonight to mock-up a "typical" amplifier. I pulled out a perfect amplifier and tangled its output with silicon diodes (I have a good sense of where they get bent).
FWIW: some milder fuzz-boxes are fairly similar to this plan.
The "perfect" amp has gain of 10. If we measure its output (red line), it is always exactly 10 times the input, at any input (in this plot, up to 0.3V in 3V out).
Real amplifiers (green line) won't make infinite output, and are never perfectly straight lines.
0.1V input does make almost 1V output. But 0.2v in makes +1.4V and -1.5V. 0.3V in makes +1.7V and -2V. 0.5V in, +1.8V and 2.4V. And, not shown, 5V in gives +2.3V -3V.
The output never rises past about 2 or 3 volts. And not symmetric + and -. Good to know.
If you had say a 6V6 and it needed +/-17V at the grid to smack the whole 4.8 Watts of output, this circuit won't do it.
Another tidbit you need to know: it is hard to see in this graph, but the left-right trace does not lay exactly on the right-left trace. This is phase shift. If you measure a tone control, or any circuit with limited frequency response (almost any gitar amp circuit), that ideal straight line opens up into an oval.
Another thing: you don't have to adjust the scope when you change frequency. In fact you can see nonlinearity with any signal, even if you don't know what it "should" look like. You can watch signals as you play guitar.
« Reply #3 on: June 13, 2009, 10:20:35 am »
Awesome, thanks guys.
... down to the "lab" I go...
