September 08, 2026, 11:22:05 am
Hoffman Amps Forum image Author Topic: Part Sources for 5-String Bass  (Read 9809 times)
Offline Shrapnel
« on: June 18, 2009, 12:49:45 am »
Where's the best place to get some needed parts to fix up a bass?
This is a (cheap) Rogue 5-string bass that needs at least two machine heads replaced, nuts for the volume pots, and knobs for the volume pots and tone controls. Forked out $20.00 for it, and figured it would be a decent fixer-up for  my oldest daughter to noodle and learn on. It looks a lot like the Rogue LX205B Series II, except the bridge is different (but very similar), and the branding is on the body and pickups and not on the neck. (LX205B Series 1?)
The PU's do seem to work, and right now is strung as a 4-string (but the E string's machine head has been jury rigged and will slip if not careful)
-Later!
Offline G._Hoffman
Re: Part Sources for 5-String Bass
« Reply #1 on: June 18, 2009, 01:37:14 am »
www.allparts.com
www.stewmac.com
www.wdmusic.com
www.lmii.com
Those are the basics, and should get you started.  There is also your friendly neighborhood repair shop, where I at least frequently have all the stuff you are after, or can get it for you.  I may not be in your neighborhood, but their may be a good shop near you.
Gabriel
Offline Shrapnel
« Reply #2 on: June 18, 2009, 02:31:41 am »
Thanks, I'll start lookin with these links. (std web search wasnt helpful.)
-Later!
Offline tubesornothing
« Reply #3 on: June 18, 2009, 02:37:09 pm »
What did you search for?  I googled "bass parts" and up came all parts, stew mac, and others...
Offline Shrapnel
« Reply #4 on: June 18, 2009, 06:48:56 pm »
I think I was using "5-string bass machine heads"... maybe a little too specific then.
-Later!
