September 08, 2026, 03:48:28 pm
Hoffman Amps Forum image Author Topic: Plexi 50 Watt Hot Switch Mod ?'s  (Read 8559 times)
Offline Geezer
« on: June 17, 2005, 08:45:07 pm »
        > Plexi 50 Watt Hot Switch Mod ?'s
<< Prev Topic | Next Topic >>
Author  Comment
bnwitt
Senior tube assistant
(2/8/04 12:33 pm)
 I am building two Hoffman 50 watt plexi heads and I thought I would try the hot switch/master volume mod. For those of you that have tried it, I have some questions:
1. How do you like the sound?
2. Can you switch it in and out while the amp is on without detrimental effects?
3. Assuming a yes answer on question #2, could a DPDT relay and a foot pedal be substituted for the toggle switch to bring in the effect while playing?
4. Has anyone added an additional 12AX7 and kept the dual channel setup instead of using the second channel's tube for the mod?
Barry
Edited by: bnwitt at: 2/8/04 12:34 pm
HStraub
(2/8/04 3:05 pm)
 Plexi HS
Hey Barry,
I use the mod as standard in my amps with a few modifications and I love the sound.
#2. You can switch it in and out without a problem except the volume does jump dramatically and sometimes jumps into feedback depending on where you are.
#3 Yup, check out:
www.phatamps.com/pages/5/index.htm
I haven't tried the circuit yet, but it is all there. I assume the same issue with volume will be there....
#4 Nope, haven't tried it. I go down to a single input and use the free half of the tube.
Good luck,
Harry
bnwitt
(2/8/04 6:46 pm)
 Re: Plexi HS
Harry,
thanks alot for the info, that helps alot.
Barry
 Topic Commands
Powered By ezboard® Ver. 7.32
