August 11, 2026, 10:03:42 pm
Hoffman Amps Forum image Author Topic: Vintage test equipment on Craigslist  (Read 4907 times)
Offline samwheat
« on: July 04, 2009, 04:32:23 pm »
http://baltimore.craigslist.org/ele/1236406803.html
Some of this stuff is useful but needs to be rebuilt and calibrated
The cap checkers ... all techs should have one
The VTVM's ..... good for troubleshooting tremolos and leakage ... The RCA volt/ohmyst is useless since they don't make a battery for it
Nobody should be without the EICO 1140
I think the signal generators are for TV use ..... you need one you can dial for 1kHz and 250-500mVAC output
Nobody makes these bench tools anymore
« Last Edit: July 04, 2009, 04:43:37 pm by samwheat »
Re: Vintage test equipment on Craigslist
« Reply #1 on: July 05, 2009, 01:06:36 am »
Nah... You need a 1.5v battery. A C-cell fits the clip inside the case. Soldering leads on the battery to run to the circuit board is fraught with peril, but can be done. The biggest issue is that the battery will leak corrosive stuff if it sits around with the resistance function unused for a long time.
