September 19, 2026, 06:43:32 am
Hoffman Amps Forum image Author Topic: Crown 3600 VZ FanFormer  (Read 14580 times)
Offline Tiny_Daddy
  • Get your Amp N Gear!
« on: August 29, 2009, 01:01:38 pm »
Introducing the "fanformer": I notice Crown has been using the fan motor as a transformer to get 18V for the preamp. I have a Crown with bad fan bearings and in order to replace the fan with something ordinary, a small transformer will need to be added too.
Re: Crown 3600 VZ FanFormer
« Reply #1 on: August 29, 2009, 09:13:36 pm »
That was a common trick with low-cost transistor record-players. There's ample flux in the motor stator. A few turns will steal some power. Commodity barbecue-spit motors have more than enough torque to spin a platter. It's not the most efficient plan, but it saves a part.
Offline Tiny_Daddy
« Reply #2 on: August 30, 2009, 06:41:22 am »
Sounds fine for low-cost record players. But Crown preamps? Another issue is fan noise but changing or slowing the fan now becomes a problem.
