September 17, 2026, 08:09:25 pm
Hoffman Amps Forum image Author Topic: 4-10s from a 50's Organ...Any Good???  (Read 8636 times)
Terry
  • Guest
« on: September 14, 2009, 08:25:30 am »
They say they are Jensens.  They have tiny tiny magnets These are the numbers: 220338  AO21075O (or Q).  Please let me know.  I'm assuming the tiny magnets would mean very low headroom.  Thanks
Re: 4-10s from a 50's Organ...Any Good???
« Reply #1 on: September 14, 2009, 04:35:36 pm »
Built by Jensen in the 38th week of '53 or '63.  Here's more info:  http://www.provide.net/~cfh/pots.html
http://www.webervst.com/codes.html
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
« Reply #2 on: September 14, 2009, 10:51:50 pm »
Well tiny magnets usually mean Alnico in that era..... The magnet need not be very big to work well.  It's worth trying them out for sure...just test for open voice coils with the ohmmeter first.
Open Minded But Fixed Bias
Offline Frankenamp
  • What does this button do?
« Reply #3 on: September 15, 2009, 09:41:14 am »
Look at the magnet structure- I'm pretty sure you will see a piece of 1.5"-2" 1/4" flat bar stock bent in a square shape with a round piece of metal could be cast or made out of round stock in the middle (that's the alnico slug) the square box channels the magnetic flux to the gap. Ceramic motors look different- they are round and flat with a piece of grey-black ceramic material sandwiched between the two metal pole pieces. Rear piece has a piece of round stock press-fitted in the rear. with a date code of '53 or '63 my nickel is gonna be on the alnico magnet. Alnico didn't start going scarce until the late '60's. High-end speakers (Altec, WE, JBL, Stephens etc) used a different design- the motor was cast and machined from one piece instead of being punched out from flat stock.
This problem calls for a bigger hammer!
Terry
  • Guest
« Reply #4 on: September 15, 2009, 01:26:05 pm »
No.  Thats just it.  They don't look like that.  There is no square box around the round thing.  These just look like a (for lack of a better word) nipple on the back of the speaker....and they are tiny.  The guy said there was 9 (count them...9) of these connected to a single organ.  Oh boy...this is getting scarry.
Offline Frankenamp
« Reply #5 on: September 15, 2009, 09:02:14 pm »
Hmmmm.... nipple on the back of the back of the speaker?  That's the economy-economy version! Might be good for 12 watts max- If there was an amp with a couple of 6L6's and or a quad of 6V6's- the organ would have needed them all! Xmax is probably 2mm max.
I'd use them for single end amps like champs or bronco's... may have 'tone'
