September 08, 2026, 01:57:57 pm
Hoffman Amps Forum image Author Topic: Dropping 18VDC to 6VDC  (Read 10100 times)
Offline tubesornothing
« on: September 16, 2009, 02:50:26 pm »
I have some old 6V mountain bike lights with dead lead acid batteries.  I want to cheap out an ressurect them, but use my 18V LiIon drill batteries.  I am figuring out a way that I can drop the voltage without too much waste.  Here is what I have looked at:
1.  use a series resistor - too much power waste
1.  use a zener - too must power waste?
3.  regulator - I think 18V into a 6V regulator will  cause too much power waste
4.  DC-DC converter - good idea, but the cheapest is $80
5.  Run the two 6V light in series and overvolt them - hmm, I don't want to fry the lights.
Any other suggestions?
thanks
Re: Dropping 18VDC to 6VDC
« Reply #1 on: September 16, 2009, 03:53:36 pm »
three lamps in series - no waste.
with two lamps 6V wasted - or the power of one lamp.
with one lamp 12V wasted  - or twice the power of one lamp wasted.
« Reply #2 on: September 16, 2009, 04:24:42 pm »
I only have two lamps though...  I don't really want to spend more money, if I can help it.
I did find a 6V regulator that will take up to 20V input with a 7A output for about $14 (kinda pricey) I suppose I could just get a couple of 6V 3A regulators, it might be cheaper.  Not sure, but do regulators have much waste heat with a large potential of voltage?
« Reply #3 on: September 16, 2009, 05:08:45 pm »
OK, Wikipedia says linear regulators or inefficient cause "regulates the voltage by burning off "unwanted" voltage as heat" - not what I want.
Offline billcreller
  • 1934
« Reply #4 on: September 24, 2009, 04:27:42 pm »
  Well, maybe the 2N3055 transistor and a pot for bias would be cheaper than a regulator etc. The transistor could heat sink off the bike someplace (??)
  Sorry....just another brain fart :grin:
  Oh yeah, once the correct R value was found for that voltage and load, a resistor could replace the pot ( that's two brain farts)
« Last Edit: September 24, 2009, 04:29:58 pm by billcreller »
« Reply #5 on: September 24, 2009, 04:38:12 pm »
I think I would be in the same boat - offloading the volateg difference as heat.  To much of a waste of precious power.
After a lot of looking into this, I think I will switch to LED lights. Doug and others have put out a lot of info on how to roll your won.  There are also some inexpensive DC-DC converters, so I can leverage my drill batteries.
« Reply #6 on: September 26, 2009, 06:13:06 am »
Two 3.6 lithium ion 2500mah batteries are $6.83 with free shipping
http://www.dealextreme.com/details.dx/sku.29030
7.2 volts total in series = 2500mah
4 is series/ parallel = 4800 mah battery pack
I am guessing you are trying to run Halogen bulbs?
They might not take 7.2 volts.
