September 08, 2026, 11:22:16 am
Hoffman Amps Forum image Author Topic: guitar boost ?  (Read 9899 times)
Jamie
  • Guest
guitar boost ?
« on: September 30, 2009, 03:51:36 pm »
Before this post gets moved to the dead letter office... is there away to add a signal boost/fat on a guitar with bridge, neck, one volume , one tone ?
Offline phsyconoodler
Re: guitar boost ?
« Reply #1 on: September 30, 2009, 03:56:01 pm »
Yes,but it involves adding a battery and a circuit to increase the signal strength from the pickups.
   An opamp and 9v battery and some circuitry.
Jamie
  • Guest
Re: guitar boost ?
« Reply #2 on: September 30, 2009, 04:02:26 pm »
I ask this because a friend wants me to "restore" the wiring in a messed-with 60's Tiesco , that HAD some switched boost function... he seems to remember it as adding more bass/bottom.
Offline tubesornothing
Re: guitar boost ?
« Reply #3 on: September 30, 2009, 04:24:03 pm »
Unless it had a battery it was probably taking away bass bottom end rather than "boosting it".
Offline The Radium King
Re: guitar boost ?
« Reply #4 on: September 30, 2009, 05:07:52 pm »
i don't know where i saw it, or what it is called, but there is a mod out there for passive, onboard, guitar boost. baiscally it is a diode clipping circuit - one diode or two, perhaps with a cap to round off the corners.
Re: guitar boost ?
« Reply #5 on: September 30, 2009, 05:11:57 pm »
without a battery, and hence an amplifier - it ain't a boost.  A passive diode clipping circuit will not boost the signal, it only clips it (hence the name).
If they call it a boost, its a misnomer.
Re: guitar boost ?
« Reply #6 on: September 30, 2009, 05:20:55 pm »
my bad. i was addressing the inquiry for 'fat' more than 'boost'; where a signal lightly clipped by a diode and smoothed by a cap would sound 'fat'.
