September 15, 2026, 01:12:20 am
Hoffman Amps Forum image Author Topic: Behringer amp problem  (Read 11946 times)
« on: November 01, 2009, 03:29:01 pm »
Keyboardist is using a Behringer amp as a monitor. One of the volume pots for one of the channels makes a considerable hum and has alot of volume coming thru on 0.  However, when you dial it to 2 ......... it sounds normal and like "2".
In other words, dialing to zero has more volume (plus a hum) than 2.  Probably a bad pot or would you consider some other problem?
I have not taken the amp apart & I'm not sure I want to work on it?  Do you know if the pots are in a PCB board?
with respect, Tubenit
Re: Behringer amp problem
« Reply #1 on: November 01, 2009, 06:20:24 pm »
I don't "know" (especially with the slim clue "a Behringer amp"); but I bet you a whole-house water-filter that everything is PCB mount.
I can't make sense of the symptoms. Being Beeringer, it may be considered disposable. So pop the lid, use your bright light, and look for cracked solder joints. Especially on pot-legs. But if you have to take more than a dozen knobs off or a dozen screws out to find the PCB, just scrap it.
Fools rush in. You are very wise.
« Reply #2 on: November 01, 2009, 07:55:50 pm »
Once I stopped laughing ......... your response was a good reality check for me. It confirmed my suspicions about
taking this on.  Maybe they'll chunk it for a good amp.
Thanks, Tubenit
« Reply #3 on: November 02, 2009, 10:24:44 pm »
Thanks, Tubenit
you are a wise man. :)
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« Reply #4 on: July 19, 2010, 02:08:16 pm »
very wise man , if you look up Behringer in the dictionary you see a picture of the dump lmao
                                                     Rock On
Offline tubesornothing
« Reply #5 on: July 19, 2010, 09:24:26 pm »
yeah - if you can run away, that would be good.   After my last run in with a mesa PCB, I will never go there again...
