September 18, 2026, 12:59:13 pm
Hoffman Amps Forum image Author Topic: Speakers for a Hammond organ  (Read 12851 times)
Offline punkykatt
« on: November 30, 2009, 10:11:58 pm »
I just inherited a couple of 12" speakers that came from an old (1960`s) Hammond series K-100 organ. Im trying to find out who manufactured them. The numbers on the frame are 575546 and another number which i believe is their part number AO-24346-0. I checked the EIA codes and could not fine a match? Does anyone have a clue who might have made thes speakers?  Thanks for any help.  Punky
Offline Shrapnel
Re: Speakers for a Hammond organ
« Reply #1 on: November 30, 2009, 10:42:02 pm »
575 = Heppner
a brand of speaker I am unfamiliar with.
-Later!
Offline punkykatt
« Reply #2 on: December 01, 2009, 11:40:28 am »
Thanks Shrapnel,  They look to be a decent 15-20 low wattage alnico speaker. I have never heard the Heppner name before.  Thanks again.  Punky
Offline FYL
« Reply #3 on: December 01, 2009, 12:49:59 pm »
Try this :
http://www.ecaus.org/engineering/sourcecodes.cfm
"Heppner Manufact. Co.
Round Lake, Illinois 60073
USA
Source Code: 575
Issue Date: 2/1/1981     Cancel Date: 10/27/1983
Comments: "
Hammond switched from Jensen to Heppner. Their drivers are very good, but should always be used in pairs : one is fitted with a light cone - trebly sound, the other with a heavier one - slightly muffled result. The pair gives a nicely balanced result.
Offline punkykatt
« Reply #4 on: December 02, 2009, 09:23:22 pm »
Thanks for the link  FYL.  So those speakers were only made between 1981 and 1983??   I will have to take a close look at the cones to see if I can see or feel a difference. When I get a chance, I`ll have to put them in my closed back 2-12 cab and give a ear check.
Punky
Offline FYL
« Reply #5 on: December 03, 2009, 02:27:47 am »
I'd rather say that Heppner's last avatar used the old 575 source code during that period.
One should be fitted with a ribbed cone, the other with a smooth one.
I'd rather try them in an open back cab.
Offline punkykatt
« Reply #6 on: December 03, 2009, 09:52:14 pm »
Why an open back?   I do have a Matchless 2-12 ESD cabinet with the original Matchless (branded) speakers which I cant get them off the speaker baffle, I think they installed the speakers before the paint was dry? Got any ideas how to get them off without messing up the gaskets or hacking up the baffle?
Offline FYL
« Reply #7 on: December 07, 2009, 02:45:16 pm »
Why an open back?
Their Qts is quite high, going closed back would sound boomy.
A flexible blade and lots of care maybe.
Offline softwarejanitor
« Reply #8 on: October 09, 2010, 03:07:41 pm »
575 = Heppner
From my understanding Heppner was bought out by Cerwin-Vega in the early 1970s and the brand disappeared at that time.  Prior to that they were mostly an OEM maker and their speakers were used in things like Baldwin organs and Motorola Hi-Fi consoles  either unbranded or re-branded.  I've got a pair of Heppner 475 coded speakers that are labeled "Motorola Golden Voice" that came out of an early 1960s Motorola console.  I built them into a combo amp with a Motorola HS-475 tube amp chassis which came out of a different console.
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
« Reply #9 on: October 10, 2010, 03:29:29 am »
You may also find Rola speakers in Hammonds, but that code indicates Heppner.
That would be correct.  Hammond's part numbers always have the AO- prefix. This includes speakers, proprietary capacitors, Potentiometers, Switches, etc.
They also used the prefix for larger components as whole amps.  (AO-28 B3/C3 amp, AO-29, AO35 and AO63 to name a few.)
j.
Open Minded But Fixed Bias
