September 19, 2026, 02:20:56 am
Hoffman Amps Forum image Author Topic: Relay switching noise  (Read 13942 times)
Offline Twanger
  • The tone quest never end!
« on: December 19, 2009, 03:11:18 pm »
Hi all,
In my last project im using a relay to bypass a preamp, im getting a big pop when i engage the relay, is there a fix for that ?
John
Offline jcm-jmp
    • latham custom audio electronics
Re: Relay switching noise
« Reply #1 on: December 19, 2009, 03:40:31 pm »
tie a diode across the coil of the relay. and if it still pops use a large 2200uf low voltage cap on the positive side of coil to ground.
DAZED AND CONFUSED!
Offline tubesornothing
« Reply #2 on: December 19, 2009, 03:46:05 pm »
Is the switch in series with the preamp?  This often causes pop, adding another switch shunting to ground cures the pop.
Offline JayB
« Reply #3 on: December 19, 2009, 05:38:50 pm »
That or make sure grids are not flying free before and after the relay. They need a ground reference or the voltage builds up after the cap.
You're going to hell faster than Britney Spears running to a Barber shop
Offline Twanger
« Reply #4 on: December 19, 2009, 07:11:17 pm »
thank you all for your help, I will try the tricks you proposed and see if it cures the problem.
John
