September 08, 2026, 07:12:04 pm
Hoffman Amps Forum image Author Topic: Slowing an AC induction Motor  (Read 8460 times)
Offline tubesornothing
« on: January 24, 2010, 05:52:18 pm »
This might be similar to G Hoffman's thread, but a little twist.
I bought myself a used industrial sewing machine for making amp covers.  It is excellent, but holy crap it is fast.  Efiin scarey fast.  I can probably get a smaller drive pulley, but since I got a couple of variacs kicking around, I am curious - can I use a variac to control the speed with no ill effect?  It looks like a typical 1hp 1720RPM induction motor.
thanks
ToN
Re: Slowing an AC induction Motor
« Reply #2 on: January 24, 2010, 07:24:52 pm »
Hey thanks.  Yeah I kinda thought it wouldn't just be a voltage adjustment.  I just re-read PRR's response to G Hoffman leslie motor control thread.  http://www.el34world.com/Forum/index.php?topic=7982.0  He basically says the same thing.  Since this is an industrial sewing machine, its not the typical universal motor.  Its same size as a 15A table saw motor.
I think I need to re-gear it (pulleys).  I just finished stitching up a couple of tarp zippers.  If I knew what I was doing, I could have done the 8 ft of zipper in about 30 seconds.  This thing rips.
« Reply #3 on: January 25, 2010, 06:45:29 pm »
"Sewing machines" traditionally use "Universal motors", NOT induction motors.
The no-load speed is another clue.
Does it have brushes? Does it spark?
Then maybe it IS an induction motor. But why 1 whole Horse for sewing? Why 1800 when 3600 is cheaper and it must have a belt anyway?
« Reply #4 on: January 25, 2010, 08:50:04 pm »
This is not a home sewing machine - it is an industrial machine.  1hp motor - for sure induction (i.e. not universal - no brushes anywhere).  These babies are designed to run flat out, but there speed can be varied somewhat because it has a clutch (no kidding, a real live clutch).  I spoke with the local sewing shop (which also sells the industrial machines) they sold me a pulley for $10.  He did try to upsell me to a DC motor with speed ranges - but I did not want to fork out the $300
Offline billcreller
  • 1934
« Reply #5 on: January 29, 2010, 09:11:23 pm »
I've used one of those industrial type machines. lots of power for heavy material. Don't remember if it was variable speed.
