August 29, 2026, 08:48:20 am
Hoffman Amps Forum image Author Topic: NS Mullard EL84 Reissue  (Read 12694 times)
Offline neon333
« on: January 30, 2010, 05:23:20 pm »
Just popped a pair in my amp and played for about 10 minutes and I really like them so far. Rich, creamy, and smooth is how I would describe them. Great low end and really nice high end definition. Had JJ's in previously and they always sounded a bit harsh and brittle to my ears.
I'm having some folks over tonight for a jam session so I'll let you all know what I think about them after some extended "real life" use. I'll be playing strats, teles, LP's etc., so I should be able to see how they do with single coils vs. humbuckers.
Anyone else have any opinion/experience with these tubes?
Offline FYL
Re: NS Mullard EL84 Reissue
« Reply #1 on: January 31, 2010, 08:28:54 am »
Nice tubes, but you can get as good or better results with 6P14P-EV's.
Offline neon333
« Reply #2 on: April 11, 2010, 11:45:08 pm »
I've been thinking about using the 6p14-ev's and 6n2p's in my next build.  My only concern is they draw more current than el84's and 12ax7's.  Here are some specs I found:
http://www.russiantubes.com/prop.php?t=12&p=245
http://www.russiantubes.com/prop.php?t=12&p=246
http://www.russiantubes.com/prop.php?t=12&p=197
I think I'm probably ok with the 6n2p-er.
What changes to a power supply and or transformer would I have to make to use these tubes in a 18wattish type circuit?
pax,
neon
Offline tubesornothing
« Reply #3 on: April 12, 2010, 01:11:58 am »
A little blurb about the EL84M  (6P14P-EV)
http://thetubestore.com/el84review.html#russianel84m
Offline Geezer
« Reply #4 on: April 12, 2010, 05:27:15 am »
None......the filament draw is the same, the Russians are simply giving a "range" of acceptable (within spec/tolerance) currents, vs the old standard "this tube draws 750mA".
Offline FYL
« Reply #5 on: April 12, 2010, 06:28:34 am »
Hmmm. As good as any promo blurb disguised as a comparative test.
« Reply #6 on: April 12, 2010, 08:42:27 am »
Yeah, as good as any other opinions found on internet forums.
Offline FYL
« Reply #7 on: April 12, 2010, 11:18:32 am »
 :smiley:
