September 15, 2026, 07:53:53 am
Hoffman Amps Forum image Author Topic: 5E3 Cabinet construction info  (Read 15223 times)
Offline bnwitt
  • Crankin' out the tone.
« on: February 20, 2010, 11:49:59 am »
I thought I would share this PDF document which has 5E3 cabinet layouts and tweed help I collected from the internet.
Offline heresrobert
Re: 5E3 Cabinet construction info
« Reply #1 on: February 20, 2010, 12:48:38 pm »
A two thumbs up thank you!
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: February 20, 2010, 09:54:15 pm »
You, sir, are a gentleman & a scholar, no matter what Doug Hoffman says! :wink:
Chip
Quote from: jjasilli
Quote from: PRR
Offline billcreller
  • 1934
« Reply #3 on: February 20, 2010, 10:06:31 pm »
A gentleman, scholar, and all-around good guy :smiley:   And my pal !
Offline drew
« Reply #4 on: February 20, 2010, 11:35:10 pm »
Thanks for that.  How many yards of tweed do I need to order to cover one cabinet?
Offline bnwitt
« Reply #5 on: February 21, 2010, 12:46:18 pm »
Now that depends on how many times you screw up and what tweed you are using.  The tweed I am using has the lines going from 10 oclock to 4 oclock when you hold the 64" width horizontal.  All panels need to be cut in that orientation as you are facing them or the lines don't come together correctly at each joint.  Attached is a cut plan showing how to get all of the pieces out of a single yard of material like I have.  Make sure you buy coated tweed or you'll have major edge fraying issues.
« Last Edit: February 21, 2010, 12:50:12 pm by bnwitt »
Offline billcreller
  • 1934
« Reply #6 on: February 22, 2010, 03:04:26 pm »
 I used the 5E3 cab I bought for info to build 5 of my own, but I don't use the finger joint corners. I use triangle glue blocks and West System Epoxy.
  Nice to have the real drawings though.
