September 16, 2026, 11:36:37 pm
Hoffman Amps Forum image Author Topic: speaker with multi-impedance  (Read 8374 times)
Offline skyclad
« on: February 26, 2010, 09:00:26 pm »
I just saw a picture of a JBL D130 F with stated impedance of 8 - 16 ohms. I couldn't see by the picture but am guessing is has one positive (black for JBL) terminal for 8 ohms and one for 16. What a great idea! Why don't more speakers have this feature?
sky
Re: speaker with multi-impedance
« Reply #1 on: March 01, 2010, 03:31:39 pm »
I am sure it is not dual-impedance.
If you don't use ALL the copper in the magnet gap, efficiency goes away.
There are dual-4-ohm windings for car subwoofers. These can work fine when both coils are used; either as 2 ohms or as 8 ohms. (In car-sound which is stereo and where amp-channels are cheap, the one cone is often driven with two 4-ohm amps.) This also works because small woofers must be very inefficient. But trying to wind a 8/16 coil pretty much ensures complicated and lossy external re-connections, or far more mass in cone and magnet than you would want.
Offline FYL
« Reply #2 on: March 01, 2010, 05:42:51 pm »
Standard terminals. JBL used a 6.9 ohms voice-coil and called the D130 a 16-ohm model because it's average Z was closer to 16 than to 8 ohms. The K130 reconed or aftermarket 8-ohm versions are fitted with a 5.6 ohms VC.
Offline skyclad
« Reply #3 on: March 28, 2010, 09:12:43 pm »
here's the one I was talking about -
« Last Edit: March 28, 2010, 09:17:35 pm by skyclad »
Offline FYL
« Reply #4 on: March 30, 2010, 06:49:32 pm »
Pretty standard. The electrically identical Fender version was rated at 8-ohm.
Offline jeff
  • Need input
« Reply #5 on: March 31, 2011, 01:35:51 am »
Speaking of that I have a 15" JBL 130A marked 16 ohms that measures about 5.8 ohms
« Last Edit: March 31, 2011, 01:38:03 am by jeff »
