September 08, 2026, 04:20:35 pm
Hoffman Amps Forum image Author Topic: Carvin X100B  (Read 20009 times)
Offline Tiny_Daddy
  • Get your Amp N Gear!
Carvin X100B
« on: March 22, 2010, 09:42:48 pm »
The complaint for this amp is it's just not "loud". So I check it out and sure enough even with the volume up all the way it is obvious the power amp is not being pushed. The 10K feedback resistor seemed a bit small so I disconnected it. Big change. This amp was swamped with negative feedback. The amp would self-oscillate with no speaker connected. A 100K feedback resistor seems about right.
But one channel is way quieter than the others. Anyone else know of mods for this amp?
Re: Carvin X100B
« Reply #1 on: March 23, 2010, 12:19:36 am »
check and see if your x100b is prior to rev. "C" and if yes, the power resistors (R128 & R129) on the PCB are installed underneath the PBC. they run hot, and over time burn through the board taking out the low volt +/- supply for the solid state circuitry - the bias supply cooks as well...  :sad: the rev. "C" will have 3 secondaries + a bias tap on the PT, prior revisions have two secondaries + bias tap on PT.
if they are, then consider relocating the resistors on the top of the board, raising the body of the resistors about 1/4" up off the board. if any of the traces have crystallized, bypass the trace with a jumper wire. IIRC they are 5W resistors, you probably could replace them with ohmite 8W and cool things down a bit.
on the unit i have, the damage was so catastrophic (too many smaller traces cooked away) the board was deemed unrepairable.
most of the schematics online are for the rev. "C" - if you need it, i can email you a copy of the march '82 dated schematic.
Offline jerrydyer
  • Make it one of a kind
Re: Carvin X100B
« Reply #2 on: March 23, 2010, 05:51:52 pm »
I saw a smoked one too. I have pics here somewhers.
Offline Tiny_Daddy
Re: Carvin X100B
« Reply #3 on: April 03, 2010, 01:12:43 pm »
OK got it. According to the Carvin ECO for this board's serial number, change R15 to 1.5K and change R97 (feedback resistor) to 15K.
