August 29, 2026, 09:37:10 am
Hoffman Amps Forum image Author Topic: Juke Box  (Read 17822 times)
Offline supro66
Juke Box
« on: April 10, 2010, 06:43:48 am »
This guy at work bid on a ROWE juke box and won it
He is an Enginneer
Anyway it is the same as a Guitar amp all tubes
5U4GB, 12AX7, 7868  7 TUBES
Anyway no sound
I keep telling him the MUTE SERVICE switch is on
Two sections
Preamp
Power amp
I am not going to travel 50 miles one way to turn the switch on for him
so I told hime to bring the two boxes down to me
Anybody worked on these things
OK PEOPLE I HAVE TO ADD THIS
He emailed me this back
I gave him a Mic told him to plug it into the inputs on the power amp he should get sound
came back the next day told me no sound
here is his email today
Hey, besides pulling out the mute cord and plugging in the mic box I think I MIGHT even put the fuse back I brought in the other day.
Now what is that about leading a horse to water
STAY TUNED
« Last Edit: April 10, 2010, 07:20:33 am by supro66 »
Offline labb
Re: Juke Box
« Reply #1 on: April 10, 2010, 08:02:06 am »
I picked up a Peavey Classic 50 at a pawn shop a couple of years ago for $100 because every time they turned it on it blew the fuse. Took it home, put in a slow blow fuse and it has been playing every since..They were using standard fuses..Only good deal I ever got.
Offline dynaman1
Re: Juke Box
« Reply #2 on: April 10, 2010, 08:06:23 am »
I used those outputs for a couple of 6V6 builds. What a PIA it was to figure out their secondaries!
Offline supro66
Re: Juke Box
« Reply #3 on: April 10, 2010, 09:52:07 am »
Ok he brought it into work
I guess I have a weekend project now
It looks real old and dirty inside
Caps are dried and cracked
Post pictures Monday
See it is just two amps in one
Left side and right side
« Last Edit: April 10, 2010, 10:28:09 am by supro66 »
Offline rafe
  • I have tube amps
Re: Juke Box
« Reply #4 on: April 10, 2010, 11:42:04 am »
Looks like huge iron in there.......good luck
Rafe
Offline RicharD
    • Toxic Water
Re: Juke Box
« Reply #5 on: April 10, 2010, 12:48:25 pm »
That thang looks like it's been sitting for a couple of decades.  I wouldn't dare light it up w/o a lamp limiter.  Plan on a cap job.  You might have some dry-rotted wires too.
Offline 66merc
  • Chopstick is my friend
Re: Juke Box
« Reply #6 on: April 10, 2010, 09:57:11 pm »
This looks like the one I gutted and turned into an ipod player last year.
http://www.el34world.com/Forum/index.php?topic=6030.0
Offline supro66
Re: Juke Box
« Reply #7 on: April 11, 2010, 07:49:36 am »
Here it is Sunday morning
No work today I will play with the AMP
I still think it is the MUTE switch
Lets see
 KEEP ONE HAND IN MY POCKET  :embarrassed:
REMEMBER YOU HAVE A HEART PACEMAKER NOW
Discharge caps   :rolleyes:
Re: Juke Box
« Reply #8 on: April 11, 2010, 08:06:47 am »
It'll take about a minute to find out for sure.
1. Locate that big ole 20K/10W resistor in the power supply. It should measure zero ohms because it is shorted by the mute relay MR-1 contacts. (This won't totally kill the sound)
2. Measure grid to ground resistance for V2 pin 2. It should be 1MΩ since mute relay contacts are open. (This will totally kill the sound if the contacts are closed)
3. Repeat step 2 for V5 pin 2.
Measure voltages for all tube pins (including the rectifier). That should point you toward the problem.
Re: Juke Box
« Reply #9 on: April 11, 2010, 08:25:13 pm »
> it is the same as a Guitar amp all tubes 5U4GB, 12AX7, 7868
All Audio Amps tend to use these same tubes: reckyfier, hot twin triodes, and 6L6/6V6 guts in whatever package was "new and improved" that year.
This is not a guitar amp. It is a hi-fi genre power amp. It expects a 1V signal, and most sources will need some pre-amplifier. I would not expect an audible signal from a mike, and hardly-audible from a hot solid-core guitar.
The preamp "might" bring mike/gitar up to 1V line-level.
It is very conventional except for that crazy output switching. How can you even know if you are on the right connections? That alone would explain "no sound".
Adding in the too-many connections on the preamp, this will be a hair-ripper, FAR too complicated for a highly-trained Engineer.
Jack an iPod or CD-player to the power amp Input jax, leave that preamp for another day.
Offline supro66
Re: Juke Box
« Reply #10 on: April 12, 2010, 06:13:12 am »
You are right the MIKE did not work
I was going to give him my Guitar tuner with sound
I bet that would have worked
I did use my CD player
Anyway I used WD-40 to all of the tube sockets replaced all of the tubes
Sprayed all of the switches
It worked
First CD player thru the stereo amp earphone chord into the juke box power amp
I got music
Then just the CD player no amplification thru the Preamp stage
I got music
I look at the mute switch 3 open and one shut
There is a 12AX7 tube HOLLAND it glows real red at first then goes down the other 12AX7 tube does not do that
MUTE SWITCH
POWER AMP
PRE AMP
I am going to hook up a turn table later to day
when I dig it out
The data sheet says 28 watts for the 7868 tube
two tubes equal 54 watts ?????????
« Last Edit: April 12, 2010, 06:30:49 am by supro66 »
Offline RicharD
    • Toxic Water
Re: Juke Box
« Reply #11 on: April 12, 2010, 07:57:06 am »
That's typical for some Amperex tubes.  Don't worry about it.
Re: Juke Box
« Reply #12 on: April 12, 2010, 10:48:11 am »
Yeah, for 450V cathode-bias.
Here we find 360V fix-bias. We really want to know the load impedance, but assume that smart designers simply use the tube-maker's recommended conditions.
30 Watts.
"Push-pull" suggestion is always cited for two tubes. Each pair will give about 30 Watts. The whole chassis can deliver 60 Watts.
Offline supro66
Re: Juke Box
« Reply #13 on: April 12, 2010, 10:58:29 am »
Thank you guys I can always find answers here
"Push-pull" suggestion is always cited for two tubes. Each pair will give about 30 Watts. The whole chassis can deliver 60 Watts"
Looks like the manufacture lies
Now where should I sell my BOEING stock at   :wink:
« Last Edit: April 12, 2010, 11:06:55 am by supro66 »
Re: Juke Box
« Reply #14 on: April 12, 2010, 12:03:30 pm »
No. That 330W figure is the AC input power rating. IOW, that amp consumes 330W from the wall outlet.
Offline phsyconoodler
Re: Juke Box
« Reply #15 on: April 12, 2010, 06:26:27 pm »
There are losses in any tube amp and you cannot bias to get 28 watts per tube or they'll burn up.They set up those amps so you get clean output and low distortion,so expect about 30 watts with two power tubes.This is totally normal.
  Two 6L6 power tubes have 30 watts disipation.Two of them in a push-pull amp like a super Reverb deliver about 45 watts.
  Cathode biased about 30-35 watts. 30 watts is right where you should be.
