September 14, 2026, 04:28:00 am
Hoffman Amps Forum image Author Topic: No transformer reverb with 12AU7  (Read 9863 times)
Offline tubesornothing
« on: April 11, 2010, 01:15:14 am »
I came across a reverb driver circuit which uses 1/2 a 12AU7 and no transformer.  1k/25uF cathode.  It feeds off the plate of the 12AU7 into 0.22uF coupling cap, then into a tank rated at 1.9k input.  The other interesting thing is that the plate resistor on the 12AU7 is only 10k - I presume that is to help with driving the moderately low impedance tank?  Upping the current?
The recovery is a little strange as well.  1/2 12ax7 with a 470k plate resistor. 3.3k/0.1uF cathode.
The reverb works quite well.
« Last Edit: May 07, 2010, 01:36:52 pm by tubesornothing »
Re: No transformer reverb with 12AU7
« Reply #1 on: April 11, 2010, 04:57:26 pm »
Sounds similar to some of Magnatone's circuits. Look at page 4 of this pdf...
http://home.comcast.net/~seluckey/magnatone/Magnatone_M10A.pdf
Offline caps8419
« Reply #2 on: January 28, 2016, 01:38:11 pm »
Slucky,
I know this is a very old thread but do you have a new link to this Schematic by chance? looking into a 12DW7 cap coupled reverb as well. Thanks!
« Reply #3 on: January 28, 2016, 03:08:24 pm »
Click on the world icon below my name.
Offline caps8419
« Reply #4 on: January 29, 2016, 09:58:51 am »
thank you
