September 08, 2026, 06:42:24 pm
Hoffman Amps Forum image Author Topic: Mini-HRM (Mat's amp)  (Read 29845 times)
« on: April 14, 2010, 05:10:41 pm »
I occasionally visit other amp forums and saw this amp and sound clips on the Amp Garage under the D_mble discussion.
I was VERY impressed with the sound clips and would like to build the amp.  Mat (the designer of the Mini-HRM EL84) and Colossal (who drew the schematic of the amp) both gave us permission to post an editable schematic and layout version of it.
http://ampgarage.com/forum/viewtopic.php?t=10913
Colossal occasionally visits the Hoffman forum and was aware of DaGeezer's Little Wing & HoSo56 ...... and some of the other innovative builds here. Anyhow Colossal and Mat both seem to be very cordial individuals and I am grateful for their willingness to share this.
http://soundclick.com/share?songid=8895338
http://soundclick.com/share?songid=8927753
« Last Edit: May 10, 2010, 07:18:20 am by tubenit »
« Reply #1 on: May 10, 2010, 05:38:51 am »
OK, I was going to do a 5881 SE version but that was not successful. So keeping with a low wattage amp, I am going to try Mat's preamp into a poweramp similar to the 56T using 6BM8's. This should be about a 9 watt amp.
DaGeezer tried this with his HoSo56 with 6BM8's and gave it a positive review.
« Last Edit: May 10, 2010, 07:56:41 am by tubenit »
Re: Mini-HRM (Mat's amp)
« Reply #2 on: February 12, 2011, 08:28:25 am »
Mat's mini-D amp has evolved. This is just an idea based on his latest information and soundclip.
Mat switched the V2 12AX7 out for a EF86.  He is calling it the 86-Special.
CHECK for errors and compare schematics to layouts.
I also included what I'll call Matt's mini-D hybrid.  This was based around Geezer's TBM which has an incredibly sweet clean channel.  I typically use the mid and PAB switch on ........... so I don't really need the bass and mid pot. This idea uses a 5879 pentode.
NOTE :  CHECK to make sure you are using the correct type of rectifier!!
« Last Edit: April 22, 2011, 05:38:51 am by tubenit »
« Reply #3 on: March 27, 2011, 03:51:35 pm »
We now have some voltages from Mat on his single ended 86Special.  These reflect what he has posted.
With respect, 10thtx
« Last Edit: April 22, 2011, 05:34:54 am by tubenit »
Offline tonewood
« Reply #4 on: March 30, 2011, 10:09:15 pm »
I can't seem to find a sound clip for the 86 special. Can you point me to it?
« Reply #5 on: April 04, 2011, 08:48:59 am »
Tonewood,
There are a bunch of soundclips spread over the pages of this thread:
http://ampgarage.com/forum/viewtopic.php?t=13854&start=150
Offline arjepsen
« Reply #6 on: August 18, 2014, 03:15:12 am »
Im a bit confused...
There's a 70 pf on the clean master. However it is going from wiper to ground.... Is this correct?
Usually there would be a "bright cap" from wiper to the signal side, but is this a different function? Maybe a sort of "dark cap" to bleed off a bit of treble???
« Reply #7 on: August 18, 2014, 06:33:10 am »
Tubenit prefers a smooth tone to a bright tone.
I/Tubenit do prefer a smooth tone to a bright tone, but this was actually Mat's choice.   with respect, Tubenit
« Last Edit: August 19, 2014, 01:50:59 pm by tubenit »
Offline toneseeker
« Reply #8 on: September 22, 2014, 09:07:44 am »
I am interested in building the 86-special. Has anyone completed this build? If so, could you please post some pictures of the build. Is this the current layout and schematic? Is there a BOM around?
« Reply #9 on: September 22, 2014, 09:45:59 am »
There is no BOM.  I don't know of anyone on the Hoffman forum who has built one?
I think Mat's amp has gone thru several mods & I am not sure exactly where it is now?  The original however is an incredibly good sounding amp, IMO per Mat's soundclips.
With respect, Tubenit.
Offline toneseeker
« Reply #10 on: September 29, 2014, 03:27:21 pm »
Is there any way to integrate the 86-special into one of the AX84 core power amp?
http://ax84.com/static/corepoweramps/20W_SE/AX84_20W_SE_Poweramp_Schematic.pdf
http://ax84.com/static/corepoweramps/20W_PP/AX84_20W_PP_Poweramp_Schematic.pdf
Could I go from E2 to Pin 1 on the volume control of the SE or E2 to R27/100K on the PP? There must be a better way since the 86-Special already has Vol and Mst Vol. Can it just not be done because the B+ voltages are to high?
« Reply #11 on: September 29, 2014, 03:54:56 pm »
That should work.
Offline toneseeker
« Reply #12 on: October 01, 2014, 01:28:09 pm »
I am trying to make a board for the filter section coming off the transformer. I don't understand the 22uf under the B on the schematic attached to the 1K/3W. Is the 1K/3W the same resister shown on V3-9 or a separate resister? Is this board layout correct? Where do I add the 1K/3W and the 22uf cap.?
« Reply #13 on: October 02, 2014, 07:39:26 am »
I understand it to be like this.
Please be sure to post pictures and a tone review of the amp on the Tweaks forum when you are done!
Tubenit
« Reply #14 on: October 02, 2014, 09:06:13 am »
This is how I would do it...
