August 29, 2026, 08:52:07 am
Hoffman Amps Forum image Author Topic: single tone control options...  (Read 23188 times)
Offline bruno
  • got to love that glow
« on: April 15, 2010, 03:58:05 pm »
I really enjoy single tone control amps, as I'm not big on fiddling with knobs... I love tweed deluxes for example, however I find the early single tone control from fender to be a little overly bright, and quite interactive with the tone control and overall gain of the amp!
I'd like you guys to tell me more options for single tone controls, I've been looking all over the net and found quite a few nices ones, and tubenit also gave me a nice idea of using a baxandall/james type with a dual pot. I've also noticed a lot of cool unknown amps from the 50s and 60s have "funky" tone controls which are sometimes forgotten as really good implementations. I've also been looking at local NFB options to control overall tone or power amp cut controls.
But I thought I'd ask for even more ideas, here if possible. I'm looking for something for a tone stack that allows my signal to be relatively clean and clear with good gain transition, and that is not too bright sounding like the early fender tweeds can be.
For example my ac15 twin with it's single cut control is rather jazzy sounding in the normal position, until it breaks up.
New ideas are welcome.
Offline Merlin
Re: single tone control options...
« Reply #1 on: April 16, 2010, 05:15:06 am »
I love one-knob controls too! The options are fairly limited though. Useful ones include:
Tweed Princeton: http://amps.zugster.net/images/articles/tonestacks/tweed-scheme.gif
Big Muff PI: http://www.muzique.com/lab/tone3.htm
(Also I will take the opportunity to pimp my own variation on the Big muff control:   http://i81.photobucket.com/albums/j207/merlinblencowe/BoaneRayStack.jpg?t=1271412650 and Bridged Differentiator: http://i81.photobucket.com/albums/j207/merlinblencowe/ParametricMidScoop.jpg?t=1271412680
Bridged-T: http://www.schematicheaven.com/gibsonamps/ga30rvt.pdf (See the middle control, right before the 2nd triode)
Garnet semi-active: http://www.schematicheaven.com/gibsonamps/ga30rvt.pdf (See the treble control on the 2nd triode)
There's probably a couple more, but the ones above are definitely the more versatile options.
« Last Edit: April 16, 2010, 05:18:15 am by Merlin »
Offline darryl
    • ValveTone Amplification
« Reply #2 on: April 16, 2010, 07:26:42 am »
My favorite one-knob tone control is the type used in the normal channel of the Watkins Dominator. It also appeared in a Dominator clone - the Marshall 18-watt.
This tone control can be a little dark, but a fixed or switchable bright cap across the volume control will lift the highs.
Offline Boots Deville
« Reply #3 on: April 16, 2010, 08:01:36 am »
If memory serves, I think the tone control from the 18W LiteIIB addresses the darkness issue of the original 18W.  I wanna say it's from the 18W tremolo channel, but don't quote me on that!  :smiley:
The tone control in Doug's 18W Stout differs from the 18W Lite - anyone know where that get's it's inspiration from?
Offline RicharD
    • Toxic Water
« Reply #4 on: April 16, 2010, 08:14:35 am »
Here is my current flavorite 1 knob tone control.
Offline Fresh_Start
  • noob de Lux
« Reply #5 on: April 16, 2010, 09:26:44 am »
Here's a pretty cool discussion of different tone controls:
http://amps.zugster.net/articles/tone-stacks
This discussion may also be helpful; however, my firewall labels the site "supsicious" so go at your own risk:
http://www.angelfire.com/electronic/funwithtubes/Amp-Tone.html
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
Offline stingray_65
« Reply #6 on: April 16, 2010, 10:52:33 am »
I've always wanted to try this tone stack from a Gretsch 6162.
Offline Fresh_Start
  • noob de Lux
« Reply #7 on: April 16, 2010, 10:59:23 am »
That's a beautiful hexagon, but how the heck does it work?  Is the 500K pot on the left side a volume pot (and a highly interactive one at that) or just part of the tone circuit?
Mostly rhetorical quesitons... I'll try to study it later.
Chip
Quote from: PRR
Offline echuta13
  • Elder God
« Reply #8 on: April 16, 2010, 11:00:09 am »
The "tilt" control looks really interesting.  I think Merlin mentioned the Gretsch 6162 in his book.  I've been wanting to try this out in a build.
"When choosing between two evils I always like to try the one I've never tried before."
Offline Merlin
« Reply #9 on: April 16, 2010, 11:49:43 am »
Nothing fancy, it is the same as the BigMuff Pi, except that it uses 2nd order filters instead. (e.g, instead of RC it uses RCRC)
« Reply #10 on: April 17, 2010, 06:08:50 am »
You can take most two knob tone controls and make them a ONE knob tone control with dual ganged pot.
Such as I suggested with the James tone stack. However, you could do the same thing with a Princeton Reverb
tone stack or a Dano Centurian tone stack for example.  You could even do it with a Marshall tone stack with
a fixed resistor for the mid pot etc..............
I found it relatively easy to solder a terminal strip on the back of a pot. In fact, the Dano I owned came that way.
That opens up ALOT more choices. You can also add a resistor from wiper to ground to change the taper.
Offline birt
« Reply #11 on: April 17, 2010, 12:26:36 pm »
that looks like a twin-T. used in several wah's
« Reply #12 on: April 18, 2010, 07:41:31 pm »
Pic from an earlier thread
« Reply #13 on: April 18, 2010, 10:14:12 pm »
Yes; though awful "soft 2nd order". Still that gives quite sharp slopes:
« Reply #14 on: April 19, 2010, 02:42:33 pm »
Yup the 5F2A tone stack is good enough for rock'n'roll
