September 08, 2026, 12:09:15 pm
Hoffman Amps Forum image Author Topic: Tele brass saddles  (Read 8035 times)
Offline Madison
  • What's up slobbies?
    • Funky Dolphins
Tele brass saddles
« on: April 18, 2010, 08:39:15 pm »
Wanted to comment.
I just put some brass compensating saddles on mine.
It sounds and plays way better to me. A lot warmer I think.
I got the entire "Wilkenson Licensed" bridge for cheap and decided just to use only the saddles because a new fangled shiny bridge would take away from the gritty appearance.
« Last Edit: April 18, 2010, 08:41:45 pm by Madison »
Offline stingray_65
Re: Tele brass saddles
« Reply #1 on: April 18, 2010, 10:02:42 pm »
Nice Custom!
what's that ring around your switch?
 I have to ask, how easy was it to intonate?
on the Custom my son and I built, we found 9's intonated easiest and slightly bent the long bridge saddle screws ( non compensated saddles)
Offline Madison
    • Funky Dolphins
« Reply #2 on: April 19, 2010, 12:13:04 am »
You know those 50 packs of cd/dvds?
It's the little piece of protective foam at the bottom of the ones I buy around here.
I saw it and thought "I wonder if ................"
Snug, perfect and I use light blue picks all the time, nice match.
I have a few of them saved up.Probably get creative when I get time.
Before it was crap and impossible.
Now it's much easier to intonate.
Intonation itself is almost..... perfect.(I can hear ,single octave, one or two cent errors by ear.It's a curse sometimes)
I did find that I couldn't intonate soley by the harmonic on the 12th fret.I had to press the string down to get a good estimate and go from there.....the method I prefer not to do.
I also ended up lowering the bridge PUP because the action was too close to the 1st string, causing havoc.
I am running some really old 10s now.
Hoping for more improvement with new strings.
Nut hanging things up a little sometimes.
Overall this is slowly tuning out to be a rippin' little geetar.
Offline Platefire
« Reply #3 on: May 14, 2010, 11:34:42 pm »
I put the standard old stu mac compensation brass bridge on my Hwy 1 Tele and it intonates almost perfrect. Stays in tune really well. Plate
On the right track now<><
Offline G._Hoffman
« Reply #4 on: May 15, 2010, 01:57:40 pm »
I like em.  My favorite is the Joe Barden Tele bridge, which has compensated saddles.  There are a couple other little details on that bridge which are just really nice!
Gabriel
Offline CraigB
« Reply #5 on: May 21, 2010, 07:47:56 am »
I found this to be intersting reading.  So I gave it a try.
http://www.seymourduncan.com/support/choosing-installing/tech-tips/saddle_up_your/
I was all set to buy the Wilkinson in-line bevel-compensated saddles for my new partscaster project, but wanted to try JD's suggestions first since the new bridge I bought is a fender non-compensated.  I figured, why not use what you've got, then replace with something else if that doesn't work out?
Turns out this works very nicely, if you set it up right.  I've always either bent the screw, or bought the angle-tapped kind.
Best regards,
Craig
