August 29, 2026, 09:36:41 am
Hoffman Amps Forum image Author Topic: Marshall pilot lamps  (Read 7030 times)
Offline Tiny_Daddy
  • Get your Amp N Gear!
« on: May 09, 2010, 12:38:23 am »
Which do you prefer, the 6V or the 120V lamp? I am guessing the 120V is neon and lasts longer?
Offline navdave
  • 559
Re: Marshall pilot lamps
« Reply #1 on: May 09, 2010, 02:31:05 am »
I use 6v
« Reply #2 on: May 09, 2010, 07:32:38 am »
I like the 120v. The pilot is usually sitting very near the power switch so wiring is minimal, neat, and easy.
Offline Tiny_Daddy
« Reply #3 on: May 09, 2010, 07:41:41 am »
Are they interchangeable: do they both fit in the same hole?
« Reply #4 on: May 09, 2010, 07:55:23 am »
I've never actually seen a Marshall amp, so I don't know if their 6v and 120v pilots are the same size. AES sells the square ones that look like they may fit the same size round hole.
Offline FYL
« Reply #5 on: May 09, 2010, 09:16:22 am »
Yes. Same diameter.
Offline Tiny_Daddy
« Reply #6 on: May 09, 2010, 09:30:44 am »
Thanks, I will order the 120V. It's gotta be neon.
Offline dynaman1
« Reply #7 on: May 12, 2010, 07:12:57 am »
Believe it or not, Radio Shack has them.
Offline Geezer
« Reply #8 on: May 12, 2010, 07:51:44 am »
Ha, they sure do.....
http://www.radioshack.com/product/index.jsp?productId=2102793&CAWELAID=107592184
Offline labb
« Reply #9 on: May 14, 2010, 01:23:40 pm »
Take a look at Mouser 607-6010M1.  120 volt Neon rated for 25,000 hours.
