August 29, 2026, 08:48:25 am
Hoffman Amps Forum image Author Topic: mid sixties gibson - rotary power switch  (Read 11857 times)
Offline smolder
« on: May 23, 2010, 02:16:41 pm »
Hey Guys,
I picked up a GA-35 RVT Lancer a while back that is like brand spanking new. I wanted to put in a three prong power cord, remove the death cap, and it made sense to me to disable the polarity function (like I do on my fenders). The power switch is a rotary four stop with: off | standby | on | on .
So I wired in the new cord with white and black where they were previously and the green on the closest mount of the PT. I then removed the death cap between the rotary switch and ground. Now I blow a fuse when I switch from standby to on.
Does anyone have a wiring diagram for this switch? This seems like a simple update that tons of techs would have done and I can find no information about it. Worse... I can not seem to wrap my head around how this switch works and how it relates to the schematic.
Any help would be greatly appreciated.
Re: mid sixties gibson - rotary power switch
« Reply #1 on: May 23, 2010, 02:28:47 pm »
Recheck your wiring. Wire it according to this schematic but omit the cap.
http://www.schematicheaven.com/gibsonamps/ga35rvt.pdf
Offline smolder
« Reply #2 on: May 23, 2010, 02:34:01 pm »
Thanks Sluckey.... I think that is where I'm having difficulty... translating that schematic to the switch. It has the switch drawn in 4 different places. I will try diagraming how it is hooked up now an continue attempts to cross reference with the schematic.
« Last Edit: May 23, 2010, 03:20:21 pm by smolder »
« Reply #3 on: May 23, 2010, 03:09:09 pm »
Something else must have happened while you were doing this. Doing only what you said would not cause this.
Offline smolder
« Reply #4 on: May 23, 2010, 04:25:27 pm »
You are correct. I also replaced the two 20/20 filter caps and the 20uf bias cap. Pretty much red to red and black to black drop ins.
Offline smolder
« Reply #5 on: May 23, 2010, 05:15:54 pm »
here is what I have and it seems consistent with the schematic. But like I said... the way the schematic is drawn is not easy (at least for me) to map it to the switch.
EDIT: Tried to get the full size pic to work, but for some reason it refuses to.......maybe try reloading it to photobucket.
« Last Edit: May 23, 2010, 09:06:59 pm by smolder »
Offline smolder
« Reply #6 on: May 23, 2010, 09:07:45 pm »
replaced with a more stealth jpeg and a png below:
« Reply #7 on: May 23, 2010, 09:27:31 pm »
This could definitely cause the symptoms you describe if something went wrong. Recheck your work.
Offline smolder
« Reply #8 on: May 24, 2010, 07:33:12 am »
OK... I will try putting the old caps back in this evening to see if the amp fires up.
Offline smolder
« Reply #9 on: May 24, 2010, 08:14:34 pm »
ack... good lord. So if the 25/25 dual caps I put in were only 25 watt instead of 450... that would probably do it, right?
« Reply #10 on: May 24, 2010, 08:28:43 pm »
We need to see a picture.
Offline smolder
« Reply #11 on: May 24, 2010, 09:53:33 pm »
uh... no we don't.
Offline RicharD
    • Toxic Water
« Reply #12 on: May 24, 2010, 11:53:00 pm »
A picture is worth a thousand words.  If you're concerned someone will make fun of your work, don't be.  This group is the most helpful & polite bunch on the internet.  You'll get useful constructive criticism that you can learn from.  Chances are somebody might be able to spot an error from a high resolution picture.  Cheap shots are so far and few between here because we all love tube amps.
« Reply #13 on: May 25, 2010, 12:20:32 am »
Watts? There's no watts on a cap.
400-some VOLTS on a 25V cap.... well, I tried to put 1,200V (oops) on 35V caps once, and nearly blew-out the building.
Offline smolder
« Reply #14 on: May 25, 2010, 07:18:06 am »
I can put pictures but they won't really show anything. I mistakenly ordered 25/25 F&T's without looking at the voltage (not wattage). I'll throw a pair of 22uf 450's in each place and shoot what it looks like. Gibson layouts are really a mess btw. The caps did not blow... I was blowing a fuse before that seemed to occur.
I'm rarely embarrassed about making mistakes... that's how we learn, but when they are so obvious that we look right by them I tend slap myself up on the head. My response was more a riff on the 'we need pictures' call.
« Reply #15 on: May 25, 2010, 07:41:23 am »
That 25/25@25v will probably work for the bias caps, although I'd be more comfortable with 50v-100v rated bias caps. They definitely won't work for the B+ caps. Did you put them in the B+ line?
Offline smolder
« Reply #16 on: May 25, 2010, 09:34:10 am »
Yes, in this amp there are two 20/20 450v electrolytics that are used for filtering. There is another 20uf that sits on the bias pot (at least that is what I think it is - it's not on the schematic). There are a pair of 25uf 25v caps that sit right off the filter caps in the power section as well. I am going to leave those for the time being. When I got the amp is was lacking some volume and had a slight hum... and the electrolytics in the filter section were original.
Offline smolder
« Reply #17 on: May 30, 2010, 09:45:14 pm »
sorry it took so long for picks. This is the final (and fully working) cap job. It is not the most elegant. Had I to do it over again, I would likely use a 4x20 cap can with a mount. But this works, is sort of in keeping with Gibson's tendency towards flying components - and it should hold up just fine.
Thanks for all the help guys. I really do appreciate it.
Offline birt
« Reply #18 on: May 31, 2010, 10:28:49 am »
looks very clean
