August 29, 2026, 08:49:46 am
Hoffman Amps Forum image Author Topic: AC 30 type help?  (Read 5134 times)
Offline jerrydyer
  • Make it one of a kind
AC 30 type help?
« on: May 25, 2010, 02:54:33 pm »
Ceriatone liverpull with like a parasitic osillation goin on. Half volme I get a farty type sound a little like blocking distortion but the not doesnt fade it just has lots of breakup (wrong kind) Sheilded only to the first grid. more sheilding /  ?
thanks in advance y'all
Offline Geezer
Re: AC 30 type help?
« Reply #1 on: May 25, 2010, 03:10:02 pm »
Have you done any "chopsticking" to see if you might be able to locate where the problem is occuring?
Offline Leevi
    • Rikstone
« Reply #2 on: May 25, 2010, 04:18:42 pm »
- the grid stoppers (1.5K resistors) of EL84 must be close to the pins
- check signal wires especially around the PI that the incoming and outgoing wires are not too close to each other
/Leevi
Offline jerrydyer
« Reply #3 on: May 26, 2010, 11:46:51 am »
thank you all. turned out to be a bad ground in two spots.   shipped to wisconsin today. sounded killer. the liverpull is cool.
