September 18, 2026, 06:24:36 pm
Hoffman Amps Forum image Author Topic: How to elimate POP  (Read 10134 times)
Offline Leevi
    • Rikstone
How to elimate POP
« on: June 13, 2010, 09:02:52 am »
Any ideas how to prevent POP in the following circuit when switching form bypass to operation.
I have tried resistors over the switches but it does not fully eliminate it. Smaller resistor are better but
then it is not really bypassed any more.
http://s218.photobucket.com/albums/cc183/kz14100/?action=view&current=RikstoneReverUnit.jpg&newest=1
Leevi
Offline VMS
Re: How to elimate POP
« Reply #1 on: June 13, 2010, 09:47:26 am »
Have you tried it like this?
Offline Leevi
    • Rikstone
« Reply #2 on: June 13, 2010, 11:35:37 am »
Thanks VMS
That solution is much better. There is still some snap but not a loud POP any more.
/Leevi
Offline VMS
« Reply #3 on: June 13, 2010, 12:27:29 pm »
Here's a couple more things to try to get the snap out. First I would change the order of the first two resistors and if that doesn't get rid of the snap, then I would try a big resistor across the output.
Offline Leevi
    • Rikstone
« Reply #4 on: June 13, 2010, 02:23:06 pm »
Thanks, I can not test that right now since one of the relay pins was
broken. After I have got a new relay I'll come back.
/Leevi
Offline Shrapnel
« Reply #5 on: June 14, 2010, 04:55:36 am »
Another option is use a high resistance resistor (i.e. 10M) from center to each side of the switches. This should give just enough electrical connection to eliminate the popping, and yet not bleed signal.
-Later!
Offline dude
« Reply #6 on: June 14, 2010, 12:06:09 pm »
I know I don't have a lot of knowledge to give but I had a pop every time I flipped on the stand-by in an Ampeg J20, they had the stand-by off the ctr tap of the PT. When I changed the stand-by off the rectifier I got this loud pop turning it on and/or off I can't remember. I saw some old Fenders had a 47uf 500v filter cap off the stand-by. This stopped the pop. I guess I could have used a smaller filter but that's what I had, I have an 5AR4 in that amp.
I've read about using a R here, maybe I should have gone that route but the filter worked great. I also notice that David Allen of Allen Amplification used a filter cap here in a lot of his Fender copies, I have one with it. That's why I did it.
al
Offline Leevi
    • Rikstone
« Reply #7 on: June 15, 2010, 03:05:37 pm »
Thanks, this helped a lot. The snap is on acceptable level now.
/Leevi
Offline RicharD
    • Toxic Water
« Reply #8 on: June 15, 2010, 03:39:20 pm »
You say relay so I have to ask:  Do you have a protection diode across the relay coil?  Very very important.  Eliminates pop & keep the relay healthy.
Offline Leevi
    • Rikstone
« Reply #9 on: June 16, 2010, 06:58:50 am »
No, I have normally used capacitor which is probably not the same thing.
How does the diode eliminate pop which is caused by the switches of the relay?
/Leevi
Offline RicharD
    • Toxic Water
« Reply #10 on: June 16, 2010, 08:25:20 am »
Quote from: prr
Same as the ignition coil in your car. Flow 12VDC at it, break the circuit, the coil kicks to 400V.
In theory: the current in a coil can't stop instantly, just like the voltage on a cap can't decay instantly. If you break the circuit, where does the current go? It "backs up" as a high voltage, trying to find a place it can go. In a spark coil, it breaks-over at the spark plug. In a relay, it may breakover at the switch, especially if the switch is a wimpy transistor. If there is no place to breakover, in theory the voltage rises to infinity. In practice an iron-core coil rarely kicks more than 10V the former DC voltage because the iron saps some energy (spark coils do a bit better).
http://www.el34world.com/Forum/index.php?topic=8089.0
Offline Leevi
    • Rikstone
« Reply #11 on: June 16, 2010, 01:26:00 pm »
Sounds promising but I believe in that after I have tested it in practice.
Thanks for the tip.
Btw. the popping is a general problem also when using mechanical toggle switches.
By replacing a relay by a toggle switch you should get rid of that problem according
to this theory because you do not have anything that "backs up" as a high voltage?
/Leevi
Offline RicharD
    • Toxic Water
« Reply #12 on: June 16, 2010, 01:47:39 pm »
Yes and no.  Depends on the quality and type of switch.  A make before break switch will pop less (usually) and a break before make switch.  I do know for certain relays pop without the protection diode (forward bias, points to + across the coil) and they will fail prematurely.  Another trick is to put something along the lines of a 4M7 resistor between the secondary switch legs.  Look at a Ceriatone EF86 tone control.  They're using a 5M1 between each switch leg to shunt transients.
http://www.ceriatone.com/images/layoutPic/marshallLayout/36WEF86NewCeriatone.jpg
Offline Leevi
    • Rikstone
« Reply #13 on: June 16, 2010, 02:11:21 pm »
Yes, I agree, I have used that successfully in many amps.
By using several relays for switching you can control the switching e.g. delay the break by using a capacitor. In that way it is possible to create a working "make before break" switch.
/Leevi
