September 14, 2026, 02:57:05 pm
Hoffman Amps Forum image Author Topic: One tube pulsing in a quad  (Read 4932 times)
Offline jerryjg
« on: June 24, 2010, 01:12:39 pm »
I have a amp, a Bogen amp that one tube in the quad of 4 7868's is pulsing al ot brighter than the others. Doesnt matter which tube I put in that position. Also, once it arced- hadn't been fired up in awhile.  The two front tubes make a very high pitched squealing  noise when pressed down sometimes- not all the time. Any ideas whats going on here.
I played the amp for a good long while and it does seem to run cool and no issues besides that one flare up of the tube and the bright pulsing of it. Loose tube pins?
« Last Edit: June 24, 2010, 01:22:28 pm by jerryjg »
Re: One tube pulsing in a quad
« Reply #1 on: June 24, 2010, 01:39:02 pm »
One of the guys will probably tell you to make sure there's not a "channel" burnt between 2 of the terminals on the pot, and to make sure you don't have any bad solder joints.
