September 14, 2026, 02:27:01 pm
Hoffman Amps Forum image Author Topic: R.G.'s "A fake guitar for your test bench"  (Read 6114 times)
« on: June 27, 2010, 12:24:04 am »
Quote from: R.G.
I had the need for a test oscillator when I was away from my signal generator, so I trotted out the Q&D oscillator, which had been broken by its storage.
So while tinkering, I did some things to it I'd intended to do for a while. I made it fake a repeated string pluck by adding an adjustment to make the oscillation decay to zero over a second or so, and a "plucker" to fire off repeated notes.
http://geofex.com/FX_images/Fake Guitar Oscillator.pdf
You can flip it to a constant tone, too. I think this constitutes the world's most accurate, if boring, assistant guitarist.
One dual opamp and a few other parts.
http://www.diystompboxes.com/smfforum/index.php?topic=85408.0
Looks very useful.
Offline Fresh_Start
  • noob de Lux
Re: R.G.'s "A fake guitar for your test bench"
« Reply #1 on: July 04, 2010, 09:03:04 am »
Very cool concept.  I think this would be great for fine tuning preamp stages.  Use it like the "listening amp" in reverse.  IOW injecting the signal at different points to see - and hear - what the effect of each specific stage is.
I wonder how difficult it would be to add a frequency adjustment.  Not calibrated, just a way to go from say 80Hz to 1,000Hz.
Chip
« Last Edit: July 04, 2010, 09:05:10 am by Fresh_Start »
Quote from: jjasilli
Quote from: PRR
« Reply #2 on: July 06, 2010, 08:23:19 am »
How about running a signal generator through a normally-off momentary SW?  Not automatic though.
