September 08, 2026, 03:49:14 pm
Hoffman Amps Forum image Author Topic: Question for you experienced tweakers      (Read 7901 times)
Offline Geezer
« on: June 17, 2005, 09:00:24 pm »
        > Question for you experienced tweakers
<< Prev Topic | Next Topic >>
Author  Comment
dazco6550
Junior tube assistant
(2/13/04 3:07 pm)
 I have a new build that sounds great with preamp distortion. But i'm not totally satisfied with the clean-up factor when i turn the guitar vol down. I also have a peavey classic 30 highly modded which cleans up perfectly under identical circumstances.
It's not that it doesn't clean up, but that the tone changes in a way i don't care for. Seems to lose a lot more bass than mids, which i know is typical, but it's too much.
Are there any known methods/areas in the circuit that tend to affect this w/o affecting the distortion sound much when the guitar is pegged? I'm thinking likely an input mod of some sort, eh?
jc
I only work on Fender's
(2/13/04 5:01 pm)
 Re: Question for you experienced tweakers
 You could put a small value capacitor across the volume pot in your guitar. This is the same problem that a bright switcn on an amplifier fixes.
dazco6550
(2/13/04 8:52 pm)
 i have that.......been doing that for years on all my guitars. In fact, i have the bottom tone control on my strats set up to adjust how much or little hi end the treble bypass allows thru as i turn down. But this is amp thing. I'm fine with other amps, but this one just needs the mids tamed when turning down to clean up i think. i just need to know if there is an amp tweak that will cause a tonal change when the impedence changes i guess.
 Topic Commands
Powered By ezboard® Ver. 7.32
