September 15, 2026, 02:26:39 am
Hoffman Amps Forum image Author Topic: looking for green tweed  (Read 7704 times)
Offline john_t
« on: July 05, 2010, 03:34:32 pm »
I was thinking about green tweed for a champ build. Any ideas where one might find it if it is available.
thanks john
Offline tubesornothing
Re: looking for green tweed
« Reply #1 on: July 05, 2010, 05:26:09 pm »
Swart made dark brown tweed by simply lacquer spray painting the regular tweed. You might be able to the same.
Offline bbirling
« Reply #2 on: July 09, 2010, 08:23:01 am »
John,
Green Tweed is not available. Also the Tweed produced is coated and is a shade of Yellow. It also depends on where you get it. Some shades are darker than others. You may be able to tint it Blue to get a green color, but you would have to test. I use "Clear" Shellac with Transtint (woodcraft) to modify the color of Tweed cabs I build. You can then topcoat with Lacquer. Or another option is to tint the Lacquer itself. I prefer the shellac as a base coat.
Bruce
Offline john_t
« Reply #3 on: July 09, 2010, 11:05:32 am »
Bruce, thanks for the reply. I am ready to give up on the green tweed. What about vertical tweed. I cant find that anywhere either.  john
Offline bbirling
« Reply #4 on: July 10, 2010, 08:41:23 pm »
John,
That one is easy. You simply have to buy enough tweed to cut it vertical. it comes 64" wide and the "stripes" run diagonal. For a champ thats not to bad at $30.00 or so a yard retail. I would have to do the math but I would assume at least a yard to do it maybe a bit more. I build cabs as part of my business so I typically buy 50 yards at a time from the source. If you decide to go that route shoot me a PM or an email. I may be able to save you a few bucks.
Bruce
Offline john_t
« Reply #5 on: July 12, 2010, 12:15:09 pm »
Bruce, thanks for the help.  Wow your right that was easy. That never crossed my mine. I am a ways out from finished. Thanks so much for the offer on the tweed.
Thanks again John
Offline bluesbear
« Reply #6 on: July 14, 2010, 02:46:41 pm »
Just a thought:
I covered an amp in striped blue denim material from a fabric shop, same as you would tweed. It looks great.... but whatever you do, never buy brushed material. I didn't know the difference but I do now! It's slightly fuzzy. After the finish was applied, it was like spiked hair! It took about 20 sanding and finishings to get it smooth. It would have taken 2 with normal material. Maybe you can find striped green denim at a fabric store. It's worth a try. Make sure it's not brushed and you'll be fine.
Good luck,
Dave
« Reply #7 on: July 14, 2010, 03:45:11 pm »
They give the faded jean look by using sanders on the material.  I am not surprised it has a lot of hairs.
