September 14, 2026, 03:24:46 pm
Hoffman Amps Forum image Author Topic: Mosfet and VVR - wich mosfet can be used ?  (Read 7215 times)
« on: July 09, 2010, 05:52:18 am »
Here in the forum as mosfet to be used in the VVR often the indication is for nte2973 or nte2377 (this last one with less performance)
this two mosfet here are expensive (near € 15,00 each = near $ 18,00 + the shipping € 6,00 till € 18,00)
so I'm looking for other mosfet cheaper than that
also I find in my stock a pair of NEC K1462
here the datasheet (from Sanyo, not able to find the NEC datasheet)
http://www.allcomponents.ru/pdf/sanyo/k1462.pdf
and here are the datasheet for the nte2973 and nte2377
http://www.nteinc.com/specs/2900to2999/pdf/nte2973.pdf
http://www.nteinc.com/specs/2300to2399/pdf/nte2377.pdf
please can you give any help
have you councils about other (cheaper) mosfet that can be used ?
can I use the NEC K1462 and if so can I do it without changes to the schematic that uses the nte2973/nte2377 ???
MANY THANKS
Kagliostro
p.s.: the unit is a 280v-0-280v PT Tube and SS rectifier, 30W output amp
Offline FYL
Re: Mosfet and VVR - wich mosfet can be used ?
« Reply #1 on: July 09, 2010, 07:19:21 am »
You may either use an IRFP460 (500V) or IRFPE50 (800V), available worldwide at decent prices. As you're located in bella Italia, you may also consider local models from STMicroelectronics - the STW13NK50Z or any of their 500V / >7A standard N-channel power mosfets would fit the bill very nicely.
« Reply #2 on: July 09, 2010, 08:46:58 am »
Thanks FYL
Kagliostro
