September 14, 2026, 02:26:50 pm
Hoffman Amps Forum image Author Topic: More Oscilloscope Hell  (Read 8396 times)
« on: July 12, 2010, 08:51:35 pm »
After lying fallow for about 6 months I read up on the manuals, etc. and seemed to do OK with the online 'scope simulator.  So I returned to the real thing, Protek 20mHz analog scope, bought used:
DC:  VOM reads battery @ 9.45VDC.  Scope probe set to 1X.  Vertical Control set to 1.  Scope reads 2.2 Graticule lines.  That seems to be off by ~75%.  Que passa?
AC:  I can't vouch for the accuracy my vintage tube signal generator, but:  Signal generator set to 500Hz; VOM reads 3.1VAC off the generator.  Scope probe @1X.  Vertical: dial @ 0.5 reads only 2.2 graticule lines; Horizontal dial @ .2 yileds 3 graticules = .6mS the reciprocal of which is 1667Hz.  Horizontal @ .5 yileds 1.2 graticules = .6mS the reciprocal of which is 1667Hz.  Finally something matches; but it's supposed to be 500Hz, not 1667Hz.  Que passa?
Thanks!
Re: More Oscilloscope Hell
« Reply #1 on: July 13, 2010, 12:09:43 am »
The Vert and Horiz variable knobs are set to the CLICK?
« Reply #2 on: July 13, 2010, 06:26:52 am »
Also, are you measuring the time of the AC waveform for a complete cycle, ie, positive and negative half cycles?
« Reply #3 on: July 13, 2010, 08:33:33 am »
  Yes, and the inner, concentric adjustment pots are fully CCW.
Yes.
« Reply #4 on: July 13, 2010, 09:55:01 am »
The detent/calibrated position for VARIABLE VOLTS/DIV is max CW, not max CCW. Turn the knob CW until you hear/feel it click in the detent. This may be very slight but you will be maxed out. The same goes for the VARIABLE TIME/DIV pot.
Refer to page 5 of the linked manual...
http://www.protektest.com/ProdManual/Man_P3502C.pdf
« Reply #5 on: July 13, 2010, 11:06:45 am »
BINGO!  Full CW cal pot rotation works.
Vertical:  DC is dead on.  AC:  With the inner pot maxed (I can feel the detent) the scope is reading ~5VAC; the VOM reads 4VAC off the signal generator.  I assume this has to do with RMS or peak-to-peak stuff.  Horizontal:  dead on at 500Hz!!!
Thanks much!  I promised myself I would learn to work this thing before any more amp projects.
(In my defence re the pot settings, the online tutorial 'scope required setting the pots fully CCW, so I did that with my 'scope.  So you see I had absolutley no reason whatsoever to consult my Manual first.   :angel  )
« Reply #6 on: July 14, 2010, 12:24:02 am »
Every tool is different.
But most 'scope's Cal position "clicks", which is why I used the word CLICK. I thought you would find that CLICK, even if only for curiousity. Don't make Sluckey smack you with your manual.
« Reply #7 on: July 14, 2010, 03:22:38 pm »
Don't make Sluckey smack you with your manual.    :laugh:
It's amazing how you can miss the obvious when confused.  Thanks again guys for all your patient help & support.  The 'scope is now fun and useful.  Next on my agenda:  build a dummy load box; and a power tube cathode resistor box with a 500R rheostat and a set of switchable bypass caps.
Offline tubesornothing
« Reply #8 on: July 14, 2010, 03:37:57 pm »
Very cool - keep us posted.
