September 14, 2026, 12:16:31 pm
Hoffman Amps Forum image Author Topic: What's this filter??  (Read 6048 times)
Offline Geezer
« on: July 13, 2010, 10:11:45 am »
What type filter is the attached drawing? Conjunctive? Other?
(the 1200pf/150k)
It's the output couplers to the power section of a well know "physician's" Rx......
Offline FYL
Re: What's this filter??
« Reply #1 on: July 13, 2010, 12:18:23 pm »
It's basically a tone-shaping crossline damped low pass filter, connected between the PI output coupling caps and the EL84's grid R's. A conjunctive or corrective (as per RCA) filter is more or less the same, but is connected across the OT primary (or, sometimes, secondary).
Offline Geezer
« Reply #2 on: July 13, 2010, 12:22:12 pm »
Thanks FYL!
« Reply #3 on: July 14, 2010, 03:32:37 pm »
The 150K is not any different from changing the 220Ks to 56K (except it may not bleed grid-leakage as well). With 40K source and 0.01u coupling caps, bass is cut near 166Hz, an octave up from your bottom.
The 1,200pFd across stuff right-away induces some broadband loss: two 0.01u or 10,000pFd caps feeding 1,000pFd  induces 1.8dB loss. The main effect though is a high-cut near 2,840Hz. (Without such a cap, this network is flat to like 20KHz.)
It is a bandpass, 166Hz-2,840Hz, Q about 0.25 which is not ringy, center near 670Hz which is musically good.
The Rc on the left is, I assume, a common cathode bias. Perhaps for four EL84s. 250uFd is hefty by guitar custom, nothing wrong with that. If you mostly play LOUD, you might try other values down to 25uFd.
> A conjunctive
The conjunct of a cap is an inductor. There's no significant inductance here, so that line of thought is not useful.
Offline phsyconoodler
« Reply #4 on: July 14, 2010, 04:06:21 pm »
Where does the 22k resistor go?
Offline FYL
« Reply #5 on: July 14, 2010, 04:17:24 pm »
B+ dropping resistor/split plate load.
Offline Fresh_Start
  • noob de Lux
« Reply #6 on: July 14, 2010, 04:32:23 pm »
The physician's coupling caps look just like Doug's polypropelene Xicon caps! :grin:
PRR - thanks for that really clear explanation.  25th fret on high E string is about 1,400 Hz, so the high end of the bandpass is about 2x that.  If you changed the coupling caps to 0.1mfd instead of 0.01mfd, is there a proportional change you could make to the 1,200pf cap?  IOW would you need a 120pf cap to get the same high-cut point?  (probably over-simplifying the relationships... )
Chip
Quote from: jjasilli
Quote from: PRR
Offline FYL
« Reply #7 on: July 14, 2010, 04:48:16 pm »
If I remember correctly Dr. Z uses ETR polypro caps. Really nice, compact, very affordable (just like Xicon).
http://www.etr.com.tw/
