September 19, 2026, 01:12:56 am
Hoffman Amps Forum image Author Topic: Line Out For Mixer Board  (Read 5282 times)
« on: July 23, 2010, 02:25:46 pm »
Can i feed a mixer board a signal  from the PI of an amp to the mixer board
Offline RicharD
    • Toxic Water
Re: Line Out For Mixer Board
« Reply #1 on: July 23, 2010, 03:38:12 pm »
Are you trying to grab a differential output from the PI and feed into the snake?  You could by using a pair of isolation caps but it's gonna load the PI and affect what the output tubes see + the impedance is quite high.  I'm a believer that the best way is to add a speaker tap.  Embellish this to match your amp.  Add a matching transformer (DI box) to get it balanced.  Theoretically now the mixer is seeing what your speaker is seeing.
Typical Hammond organ mod.
« Reply #2 on: July 23, 2010, 07:46:38 pm »
I tried this a while ago tonight and it worked for a minute until the pot started to smoke. I did not use a 10 watt resistor across the green and black speaker feed. What am i doing wrong?
Offline RicharD
    • Toxic Water
« Reply #3 on: July 23, 2010, 08:55:19 pm »
No.  That's a speaker or a dummy load.  This circuit is for a little old 10ish watt Hammond Organ amp.  That will smoke a 1/2W pot for certain if you're using a 50W amp.  This looks considerably more correct.
http://www.tkk.fi/Misc/Electronics/circuits/speaker_to_line.html
« Last Edit: July 23, 2010, 09:14:17 pm by Butterylicious »
« Reply #4 on: July 23, 2010, 09:21:21 pm »
Ok i see. I was thinking it looked more like a dummy load than a line out. I got it working with your second diagram. Thanks a mill!
