September 18, 2026, 10:50:21 am
Hoffman Amps Forum image Author Topic: Intermittent crackling noises in a new AC30 TB w or w/o a guitar connected  (Read 11530 times)
Offline archaos
Hi there,
             I've just finished another AC30 TB (w/o VIB/TREM channel) built from scratch, & it emits sometimes some crackling sounds.
             The plate res. used on V1 are 220K 1/2W Allen Bradley carbon comp, but they read 250K. Do they resist too much ?
             Can those noises be produced by stg else ?
               Thanx a lot.
« Last Edit: July 31, 2010, 12:52:30 pm by archaos »
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
Offline Dave
"Can those noises be from something else?"
Yeah, check the tubes and tension the sockets first.
Dave
Offline Tiny_Daddy
  • Get your Amp N Gear!
Check if you forgot to solder something. Also, tap around with a chopstick or plastic screwdriver handle.
Offline archaos
Thanx guys, I'll do my homework.
Mehr Licht !
Offline archaos
Homework done, nothing seems suspect ; it can crackles w/o playing the guitar too, therefore I guess it is an electrical issue...Any idea ?
« Last Edit: July 31, 2010, 07:00:30 pm by archaos »
Mehr Licht !
Offline archaos
I'm back. Perhaps stg new : when poking either the PIN2 1M grid res. of V3 (phase inverter) or the PIN2 itself it crackles ; nothing happens elsewhere.
So, is due to a bad resistor, a bad solder joint, or something else ?
Mehr Licht !
Offline RicharD
    • Toxic Water
Check the solder joint itself first.  Go ahead and reflow it.  Sometimes even good looking joints can be cold and cause crackling.  Sometimes a bad resistor can cause crackling, but usually it's a plate resistor sitting at a high potential and flowing current.  A 1M grid resistor is neither sitting at a high potential nor flowing current.  It could easily be bad tension at the socket too.
Offline archaos
Thanx a lot, I'll try & report it.  :smiley:
Mehr Licht !
That crackle may indicate a problem but it is also quite normal to poke the high impedance grid of a LTP PI and get a static crackle sound.
Ditto on touching up solder joints. Building fast and flowing solder relying on it's internal paste for new & shiny (or worse, dirty) metal can cause bonding issues. Kind of like gluing PVC pipe w/out solvent to prepare the weld as there's an unseen slippery grease film left from the extrusion process. You properly prepare pipe and fitting before gluing. In soldering you pre-tin both components before soldering but we rarely do this when the build "is on". I don't mean this to sound like soldering 101 or demeaning becuase you obvously know what you're doing to build amps like that. But for others learning, this could hopefully help them in understanding?
Keo
Offline archaos
Have swapped all the tubes with my other AC30, checked the socket tension, re-soldered PIN2, & swapped the suspect 1M res. Crackling is still there...What's next ?
Mehr Licht !
Offline Tiny_Daddy
Pull tubes, starting with the first preamp tube. Find the minimum tubes that still crackle.
Offline archaos
Excellent ! Thanx, will check...
Mehr Licht !
Offline J Rindt
As soon as I read "carbon comp", I think Noise. I am surprised they get used anymore. You may have burned up a plate resistor when you soldered, or it might just be noisy all on its own. If you can pull pre tubes and find out where the crackle is coming from, try replacing those plate resistors, try carbon film or better; unless you are worried about the components that were shelf items 40 years ago :smiley:
You can always put the CC's back in......
Good Luck
Offline archaos
V1 pulled, crackle's gone.  :smiley: What do you suggest ?
Good Luck
Thanx.
Mehr Licht !
Offline Tiny_Daddy
Disconnect the plate resistor on each section (pins 1 and 6) and see which one makes it stop.
Offline archaos
Sure I will, thanks !
Mehr Licht !
Offline archaos
Have removed the PIN 1 plate res.&  crackle is still there, I hope that's the other one connected to PIN 6. Will report this evening...
Mehr Licht !
Offline archaos
A last test on PIN 6 has finally proved its plate res. was faulty.
Tiny-Daddy I owe you beers  :occasion14: thanks again !
I must admit too, thanks to this goldmine forum I had solved a standby fuse blow due to a gassy rectifier.
Thanks guys.
Mehr Licht !
