September 18, 2026, 11:54:18 am
Hoffman Amps Forum image Author Topic: HRDx cathode diode  (Read 6065 times)
Offline J Rindt
HRDx cathode diode
« on: August 01, 2010, 05:19:50 am »
I tried searching for this, but it became a herculean task. What is the purpose of the  diode in parallel with the 1 ohm cathode resistor, on the power tubes do?
Thank You
http://www.schematicheaven.com/fenderamps/hotrod_deluxe.pdf
Offline LooseChange
    • Fix Your Darn Amps
Re: HRDx cathode diode
« Reply #1 on: August 01, 2010, 06:05:44 am »
I'm going to guess it's there if the 1ohm burns. The 1 ohm is there to check the bias of the two tubes.
Call me Dan
www.fydamps.com
« Reply #2 on: August 01, 2010, 09:33:03 pm »
I'm going to be rude and say "It's stupid".
There is NO way that resistor is in-trouble in normal operation. It takes 1 Amp to cook it, the tubes will never get over 0.2A-0.3A RMS, 0.4A peak. So the diode never does anything in normal operation.
If the 1 ohm 1W resistor is endangered, the 6L6es and PT are already cooking. I'd rather have the 1 ohm burn than have the diodfe "save" it so the expensive stuff burns.
Offline J Rindt
« Reply #3 on: August 01, 2010, 09:38:44 pm »
Thank You
That is kind of what I thought, but do not have enough electronics knowledge to justify shooting my mouth off. I wonder if Fender had problems/foresaw problems in this part of the power supply. is this something that is common in modern day Fenders?
Thanks Again
« Reply #4 on: August 02, 2010, 09:47:37 am »
I'm guessing it's some kind of failsafe protection in conjunction with the diodes on the plates.
