September 18, 2026, 06:39:27 am
Hoffman Amps Forum image Author Topic: Power Transformers & Rectifiers Reference  (Read 5035 times)
Offline Fresh_Start
  • noob de Lux
« on: August 04, 2010, 09:30:02 am »
Someone posted a link to this on AX84 and I thought it might be useful:
http://www.hammondmfg.com/pdf/5c007.pdf
Chip
Quote from: jjasilli
Quote from: PRR
Re: Power Transformers & Rectifiers Reference
« Reply #1 on: August 04, 2010, 12:19:56 pm »
Yes that's been banging around here.  Just posted it yesterday in another thread.  Warning:  for the CT circuits this Hammond chart measures secondary VAC from outside to outside thereby doubling the voltage as usually stated.  Then compensates by halving the forward conversion factor  -- one would think that the forward conversion factor should be kept as a constant.  Can be confusing.
« Reply #2 on: August 04, 2010, 01:35:37 pm »
Could you work the math/show the calculation for figuring out the current availability for the full wave bridge capacitor input load example?
Here's two transformer's specs to use for examples as given from two diff websites:
1) Primary 120VAC, Secondaries 306V at 27mA, 6.3V at 1.05A.
2) 18VA AC secondary 120V @ 87 ma 6.3V @ 1.2A
V (Peak) D.C. = 1.41 X Sec. V A.C.
V (Avg) D.C. = 0.90 X Sec. V A.C.
I D.C. = 0.62 X Sec. I A.C.
« Last Edit: August 04, 2010, 01:43:39 pm by jojokeo »
