September 17, 2026, 08:40:00 am
Hoffman Amps Forum image Author Topic: MORLEY PWB  (Read 9934 times)
MORLEY PWB
« on: August 07, 2010, 12:49:44 pm »
I got this MORLEY Power Wah Boost. The pot is numbered differently with 134-6551. Is this 1975? I am used to seeing 137-6551 and that would be 1965
Offline stingray_65
Re: MORLEY PWB
« Reply #1 on: August 07, 2010, 10:07:38 pm »
I'm confused about your query.
Are you trying to date this pedal?
or are you trying to authenticate the pot?
that Stancor PT in the corner should have a EIA number stamped in its frame that may clue you in to what you're looking for.
LOL however If you're trying to show off a new find, you've done that superbly!
Tel-Ray's Morley pedal are likely to be the most rugged designed pedals anywhere!
run off of mains current too! no 9V batteries or wall warts!
not to mention there is enough chrome there to patch a Buick grille
Ray
Re: MORLEY PWB
« Reply #2 on: August 08, 2010, 02:48:35 pm »
I am trying to Date the pedal. 134 is CentraLab and the last four digits should be the year and the week made. The pot itself would be like October 1965. I will remove the bottom plate later and read the Stanco transformer number.  Im a pic freak. I have over 680 of them so far. It's a library thing!
« Last Edit: August 08, 2010, 05:33:00 pm by plexi50 »
