August 29, 2026, 08:27:22 pm
Hoffman Amps Forum image Author Topic: Looking for a reliable bias meter  (Read 9317 times)
Offline angushung
« on: August 09, 2010, 04:46:16 pm »
Can anyone tell me a good bias meter that wont break my bank and can handle my 100 watt (4x EL-34b, 4x KT-88's,) heads?
Offline RicharD
    • Toxic Water
Offline angushung
Re: Looking for a reliable bias meter
« Reply #2 on: August 10, 2010, 05:35:06 am »
Looks easy enough...and its in my price range. Would I need to build 2 in order to take on a 100 watt amp properly? Or would 1 tube at a time get me there?
Offline tubesornothing
« Reply #3 on: August 10, 2010, 06:32:03 pm »
One will get you there.  Two will be faster.  Four will be really fast.  Super duper fast if you have four meters for each of them.
But, one is good enough.
« Reply #4 on: August 10, 2010, 07:43:05 pm »
get and build 4 then build 4-to-1 switch box - that way you don't need 4 meters. it's royal PITA to check bias on one tube then let the amp cool down to check the next, etc... not very efficient.
--ISO
« Reply #5 on: August 10, 2010, 08:29:14 pm »
Use silicone oven mitts...
« Reply #6 on: August 10, 2010, 09:25:48 pm »
not wise to pull tubes hot... even w/ mits.   :lipsrsealed:
« Reply #7 on: August 11, 2010, 12:08:31 am »
bah!
Offline angushung
« Reply #8 on: August 11, 2010, 05:23:18 am »
I only have one decent meter. I guess I'll need to figure out what I'll need for a switch box.
Offline malt
« Reply #9 on: August 11, 2010, 07:07:56 pm »
This may help you http://www.geofex.com/FX_images/biasprob.gif but I think you have to wire the resistor to pin 8
Offline malt
« Reply #10 on: August 11, 2010, 07:20:34 pm »
I have some parts for a bias box but I still need some parts, got to order some from Doug.
well here is what i got so far
