September 19, 2026, 07:52:10 am
Hoffman Amps Forum image Author Topic: Power transformer getting scorching hot  (Read 8893 times)
Offline jerryjg
« on: August 11, 2010, 10:03:10 pm »
After about 20\30 minutes the power transformer on this Montgomery Wards Valco amp I juts bought off ebay ( all original) gets Scorching hot- too hot to touch. The can cap seems to stay fairly cool. Loosk like a decent amp tonewise. Its plays pretty well and sounds good with no 'rice crispies' ( snaps, crackles ,or pops).
Any idea what might be going on here?
Re: Power transformer getting scorching hot
« Reply #1 on: August 11, 2010, 11:33:55 pm »
Trannies in old amps, particularly bargain amps of the day, ran hot normally.  A metal tranny can run as hot as a glass tube w/o damage.  If it can't set paper on fire it's probably not a problem.
Offline LooseChange
    • Fix Your Darn Amps
« Reply #2 on: August 12, 2010, 05:06:32 am »
You could test it to see if it has a short.
Disconnect the PT from everything and see if it draws current.
I had a Hammond organ that had a PT that got really hot in 5 to 10 minutes of use. The amp played fine. I disconnected everything and and all I had to do is run it through a light bulb limiter and the light bulb lit up. Replaced the PT.
Call me Dan
www.fydamps.com
« Reply #3 on: August 12, 2010, 10:42:25 am »
Fair enough.  You might also try the Jack Darr test to m ake sure there is no voltage on the chassis, set forth in this thread:  http://www.el34world.com/Forum/index.php?topic=9833.msg89568#new
