September 17, 2026, 11:52:31 am
Hoffman Amps Forum image Author Topic: remove me  (Read 5320 times)
ampcabinets
  • Guest
remove me
« on: August 13, 2010, 11:02:04 pm »
 :lipsrsealed:
« Last Edit: September 27, 2010, 05:24:58 am by ampcabinets »
Offline Geezer
Offline stingray_65
Re: geezer
« Reply #2 on: August 14, 2010, 06:52:11 am »
I guess it fits the 5E3 chassis
With at least 7 knobs and 1 switch on the panel plus input an a pilot lamp and power switch it's a long faceplate.
I'm using 8 pots (fatness on front) 2 mini switches  foot switch and had to do careful measuring to get it to fit into a 19" wide chassis.
If I had it available I would have put it in a Super Reverb style chassis at 24" just to keep things less cluttered.
Ray
« Last Edit: August 14, 2010, 07:00:27 am by stingray_65 »
Re: geezer
« Reply #3 on: August 14, 2010, 07:03:13 am »
I agree that it would be a very tight fit with a 5E3 chassis.
But it would probably fit in a "blank" 18 watt chassis (20" x 6" x 2.5") that you punched out yourself.  IF I were attempting that, I'd use 1M mini-pots for the clean and OD tone stacks and I would plan on using a 50k internal trim pot.
It would be input, volume, clean tone (mini-pot), level, drive, OD tone (mini-pot), mini-toggle,  clean mstr vol, &  PPIMV.
It would be tough adding relay switching in a small chassis so you might be stuck with a mini-toggle DPDT.
I think the amp is well suited for a head cab.
