September 17, 2026, 10:51:39 am
Hoffman Amps Forum image Author Topic: Tube effects loop  (Read 9546 times)
Offline 67polara
  • Here is my Guild 67 polara
Tube effects loop
« on: August 17, 2010, 09:32:09 am »
I am sure this has been discussed before.  I want to build the Tweed Overdrive Special, but I would like a buffered effects loop.  I am looking at the Dumblator circuit and I have a few questions.
1.  What tube is being used?  AX, AU, AT???
2.  What voltage on plates?
3   What do the 2 switches do?
4.  Will it change the tone any?
Thanks for all your help
Tony
http://www.schematicheaven.com/dumbleamps/loop.pdf
Offline 67polara
Re: Tube effects loop
« Reply #1 on: August 18, 2010, 09:03:12 am »
Did I place this in the right area?  Never mind I will figure it out myself.
« Reply #2 on: August 18, 2010, 08:43:18 pm »
Here is some more info on effects loops:
http://www.el34world.com/Forum/index.php?topic=4274.0
Offline 67polara
« Reply #3 on: August 18, 2010, 10:12:07 pm »
Thank you tubenit that helps a lot.
Tony
« Reply #4 on: August 19, 2010, 06:10:50 am »
Some of the D_mble cloners use this IronSounds effects loop and give it favorable reviews.
Relatively inexpensive and compact:
http://www.ironsounds.com/
