September 15, 2026, 02:20:11 am
Hoffman Amps Forum image Author Topic: Power supply resistors  (Read 9131 times)
Offline duke of earl
  • Bird is the Word
« on: August 17, 2010, 08:46:55 pm »
I have noticed that the power supply resistors between the screen, pi, and preamp filter caps on Fender amps vary in value from amp to amp. Is there a relationship for resistor value in regard to the cap value?
Re: Power supply resistors
« Reply #1 on: August 17, 2010, 09:39:03 pm »
Yes, but we don't really care  :grin:  The filter caps discharge to even out ripple.  The values of the caps and resistors determine the timing of the discharge.  So, this will affect how well ripple is smoothed.  But these component values also affect the value of B+ voltage.  For guitar amps, the ripple will be smoothed well enough.  Voltage is more important to us.
« Reply #2 on: August 17, 2010, 10:57:29 pm »
The resistor values are usually chosen in order to drop the voltage to the value desired for the circuit powered by a B+ node. They also provide a decoupling value between nodes.
Offline TweeDLX
  • Shoor, ve fix dat right op!
« Reply #3 on: August 17, 2010, 11:38:38 pm »
This is something I'm interested in, too. Could you elaborate a bit more, Sluckey? Is there a formula for calculating voltage drop in power supplies? Thanks!
Simple plan: Kill Moose and Squirrel!
Offline FYL
« Reply #4 on: August 18, 2010, 03:43:10 am »
Ohm's law... U = R * I, the voltage (in volts) dropped across a resistor equals resistance (in ohms) times current (in amperes). Example : 10K resistor, 2 mA current drawn thru it => 10,000 ohms times .002 amperes = 20 volts.
And the full version:
From DIYaudioprojects.
Offline Fresh_Start
  • noob de Lux
« Reply #5 on: August 18, 2010, 08:40:16 am »
FYL - thanks for that "Ferris Wheel".  I added it to the References sticky.
Chip
Quote from: jjasilli
Quote from: PRR
Offline TweeDLX
« Reply #6 on: August 18, 2010, 08:47:39 am »
Well...duh!  :grin: I should have known that. Thanks! That's a pretty cool graphic. I saved it in my tech file.
Mike
Offline archaos
« Reply #7 on: August 18, 2010, 09:04:45 am »
Very cool & useful wheel, thanx.  :wink:
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
« Reply #8 on: August 18, 2010, 09:32:22 am »
And all the formulas on that wheel can be easily derived from two basic formulas, V=IR and P=IV .
« Reply #9 on: August 18, 2010, 04:01:12 pm »
easily   :laugh:
  • Bird is the Word
« Reply #10 on: August 18, 2010, 05:47:27 pm »
Are these also the B+ dropping resistors?
« Reply #11 on: August 18, 2010, 05:49:27 pm »
yes.
  • Bird is the Word
« Reply #12 on: August 18, 2010, 09:03:08 pm »
That explains the different resistors. Bigger resistors means less voltage on preamp tubes for earlier breakup. I smell what your steppin in!
« Reply #13 on: August 19, 2010, 10:11:59 pm »
If caps are expensive, signals are small, and low B+ buzz is desired, you pick the dropping resistors to drop 20%-30% of raw B+.
The old Heath mono phono preamp started from 440V and dropped to 130V at the first stage. This allowed very low hum and a small total size (small 4-section cap).
You can figure "20%-30%" by assuming the tube-stage is a "resistor". We know the usual 12AX7 stage with 1.5K and 100K sets its plate at 70% of the stage B+. The 100K plus tube acts very much like a 333K resistor.
For 20%-30% drop into a 333K load, simple math will tell you to use a 83K to 142K dropper.
You can put two sequential stages on one dropper/filter. Then the resistor must be half value: 42K to 70K.
We have 4-stage amps. The later stages don't need full filtering. And three sequential stages on one filter may motorboat. So we have two filters. The one which passes current for four stages must be 1/4th value: 22K-33K.
When signals are high and you want large B+ to cover the signal, you drop 20%-10%, even 5% per section, and up-size the caps to kill the hum/buzz.
This leads to values near a dozen K. And because drop is low, the exact value is not critical. Obviously Fender used 10K and 4.7K kinda interchangeably. While 130V is different from 330V, 330V and 360V are practically the same.
For 12AX7-size tubes at resonable currents, several 20uFd-40uFd caps will clean-up even with "small" droppers (a few K). So we really don't worry about it.
It is possible to run more than 2 stages on one filter without motorboating. Especially with the short bass response favored for guitar. And many-stage gitar amps have loss networks between stages so gain does not build up too fast. If you are Peavey building a million amps, you do the hard math to feed a dozen sequential crunch-stages off one giant cap. In one-off DIY, that's too much brain-pain, you buy a pack of caps and be done with it.
« Reply #14 on: August 19, 2010, 11:35:51 pm »
Meaty post, PRR, thanks!
