September 15, 2026, 10:00:36 am
Hoffman Amps Forum image Author Topic: two CF stages as a mixer  (Read 5608 times)
Offline terminalgs
« on: August 26, 2010, 02:38:32 pm »
After seeing the dual tiode gain stage mixer on a Gretsch 6160,  I thought I'd try the same with dual CF stages  (need to mix two channels, but I don't need any gain).  anyone try this?  or know of a schematic that does this?   anyway to get the component count down on this below?
(2 attachments, CF mixer I'm asking about, and the gain stage mixer from a 6160)
Offline tubesornothing
Re: two CF stages as a mixer
« Reply #1 on: August 26, 2010, 03:10:07 pm »
Why would you not just use the typical two mix resistor combination?
Offline terminalgs
« Reply #2 on: August 26, 2010, 03:33:20 pm »
Input 1 is a ef86 gain stage with a high Zout, Input 2 is a 1/2-12ax7 gain stage,  what follows on the output is a tone stack that requires a low Zin.
« Reply #3 on: August 26, 2010, 03:50:11 pm »
Cathode impedance is low and non-linear.
Two cathodes "fighting" each other will give a gain of half; no better than a passive 2-resistor mixer; however input impedance may be higher.
The maximum output of your plan, assuming 300V and 12AX7, is slightly over 1V peak with 5% THD.
For very large signals, whichever input is more-positive will swamp the other input. Distortion is gross. It may have use as a "fuzz"; there may be cheaper ways to fuzz.
The plate-mixer has a similar issue, but not so bad, and with significant gain. Clean output may be over a dozen volts.
The 2-resistor plan has no maximum level or intrinsic distortion, except that whatever the sources can do is divided by 2 (if a source cam make 50V clean, the mixed output may be 25V). The resistor value is a compromise. Values below 200K load typical sources, values over 200K shave the highs. The Designer has considerable leeway: you find 100K and 470K mix resistors (and 3.3Meg:220K when an unequal mix is wanted).
If you can accept 2:1 loss of gain, can accept ~~270K mix input, then 2 resistors is the simplest plan.
If you can't spare the gain but can drive resistances, use fairly large (330K-470K) mix resistors to a single triode hobbled for low gain (ideally "2", but since you have extra you know you'll want more).
If you must have very high impedance mixing without loss, you are probably into some form of 2-triode plate-mixing. For maximum clean output, don't tie the plates together, use two mix-resistors after the plates.
Offline Merlin
« Reply #4 on: August 27, 2010, 06:10:48 am »
The classic cathode-mixing arrangement is to take the output from one of the anodes, that way you have plenty of gain, and the input sensitivity is basically the same as a regular gain stage.
In a guitar amp there's not much advantage over a common-anode mixer though. Pretty easy to try both though, since the cathode mixer would hardly need much modding to turn it into a common anode mixer.
