September 15, 2026, 05:18:25 am
Hoffman Amps Forum image Author Topic: Fender Amp "Weak" Vibrato  (Read 9264 times)
Offline Pastortom
  • "Band-Pastor"
    • RMI Fellowships
« on: August 27, 2010, 04:02:09 pm »
Lookin' for some input.........
Generally speaking, would a "weak" intensity on a Fender Vibrato mean a "weak" optoisolator, or are there more variables that commonly cause the weakness?
Again, it works......but the intensity is just very weak......full intensity (10) acts like a 1 or 2 setting.
What say ye?
Life should be "Amplified"............Acts 1
Offline FYL
Re: Fender Amp "Weak" Vibrato
« Reply #1 on: August 27, 2010, 05:06:37 pm »
Could be a bad solder, a weak tube or a weak neon/LDR module. Begin by checking/reflowing board connections, then try changing the 12AX7 in the oscillator stage with new or known good tubes, then try a new roach. Less probable causes: defective passives - caps, resistors and pots.
Offline bnwitt
  • Crankin' out the tone.
« Reply #2 on: August 28, 2010, 12:32:57 pm »
I'd change the tube first.  You need a really strong 12AX7 in that circuit.
Offline Merlin
« Reply #3 on: August 28, 2010, 03:28:45 pm »
Why on earth would you open up an amp and start reflowing joints before just plugging in a different tube?
(It's nearly always a weak oscillator tube)
« Reply #4 on: August 29, 2010, 06:36:34 am »
I have also seen it where the bulb was not lined up with the opto in Fenders
Kind of rare, but it can happen.
You can realign the parts and re-heat shrink them.
Offline FYL
« Reply #5 on: August 29, 2010, 10:11:59 am »
Agreed, but I've just worked on two vintage DR's suffering from weak vibrato because of board-related problems. Both were fitted with recent tubes and functional roaches, both were fine after a few reflows.
Changing the 12AX7 in the vibrato section is usually sufficient with recent amps.
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #6 on: August 29, 2010, 10:33:11 am »
I have seen more than one amp with no cathode bypass cap on the oscillator tube. Result was weak oscillation, slow to start.
Offline P Batty
  • Flippism Is The Key
« Reply #7 on: August 29, 2010, 10:36:15 am »
How old is the amp?  The light sensitive resistor in the roach will lose its effectiveness over time, diminishing the effect, but definitely check the tube first.
