July 30, 2026, 07:53:35 am
Hoffman Amps Forum image Author Topic: A discovery...or am I mistaken...?  (Read 4930 times)
« on: August 27, 2010, 07:33:15 pm »
To achieve a nominal B+ voltage from a too-low-volts power transformer with no CT, a voltage doubler is indicated.
On a salvaged power transformer from a full-wave set (like an old TV power transformer) it's pretty much a given that you'll not find a bias tap, hence you'd normally take a leg of the HV secondary, throw in a reverse diode, work out a sufficent dropping resistor, and make your negative voltage.
But you cannot do both!
You can't grab one of the HV output legs of a non-center-tap power transformer and make a bias supply using a reverse-biased (eg; "backwards") diode IF your B+ circuit is a voltage doubler.
In other words (or symbols, actually) THIS WILL NOT WORK!
Re: A discovery...or am I mistaken...?
« Reply #1 on: August 27, 2010, 08:09:38 pm »
Can't you just pull it of the leg before the doubler?  Or am I mistaken!  Someone else weigh in please!
Offline Dave
« Reply #2 on: August 27, 2010, 08:24:58 pm »
Any of the Bogen CHB amps did it.
Dave
« Reply #3 on: August 27, 2010, 09:14:22 pm »
Dave, you're absolutely right. I knew it had been done somewhere. Must be that .22 cap separating the voltage double from the bias section.
http://schematicheaven.com/hifiamps/bogen_chb100.pdf
Update: It worked!
« Last Edit: August 27, 2010, 11:10:06 pm by eleventeen »
Offline bluesbear
« Reply #4 on: August 27, 2010, 10:42:46 pm »
This looks like a job for cathode biasing!
Dave
