September 08, 2026, 01:10:56 pm
Hoffman Amps Forum image Author Topic: New Design  (Read 16510 times)
Offline escopunk
New Design
« on: August 29, 2010, 12:58:03 pm »
Hi guys,
I am working on a new design, this has attributes from many amps and the goal is to have a PCB designed that can be populated and will be flexible eough to be almost any modern high gain amp i.e. a boogie dual rec W/O the rectifiers, who needs them with high gain? Anyway this is a work in progress and will be switched to KiCad as this is the design package that I am going to use from now on, (Schematic capture, PCB layout and even 3D for free!!!!!, some learning curve) Anyway be gental, THIS IS A WORK IN PROGRESS!
Brain TM
Offline Cups
Re: New Design
« Reply #1 on: September 14, 2010, 10:28:25 am »
Wow, that looks amazing. I have no critics (especially since it's a little over my head)
I do have to say that usually you see amp layouts in a more rectangular (not so square) fashion. What kind of chassis are you planning on using?
Offline tubesornothing
Re: New Design
« Reply #2 on: September 14, 2010, 10:44:46 am »
I have learned the hard way (many times too), is not to even consider PCB for a main board unless I plan on making numerous identical amps.  Once I have made this decision, I dont even start on the PCB, until the design has been proven with a solid working prototype - with all tweaks resolved.  Then I check the schematic 450 times against the working prototype before taking it to PCB design.
However, I have completely abandoned using PCB for the main board.  Might look cool, but way too much trouble for building less than 100 of the same amps per year.  However, I do use PCB for small "modules":  channel switcher,  relay PCB, james tone stack, etc.
Offline escopunk
Re: New Design
« Reply #3 on: September 15, 2010, 01:28:08 am »
A little update, and yes doing a design like this is risky, I will proto the design before I ever have one made and I do verify the designs 500X.  Enjoy
Re: New Design
« Reply #4 on: September 15, 2010, 01:04:10 pm »
Well at the very least, it *is* fun and a valuable learning experience.
