September 14, 2026, 09:11:43 pm
Hoffman Amps Forum image Author Topic: reverb self crashing  (Read 6229 times)
Offline Searing
  • All's well that sounds well
« on: September 01, 2010, 12:09:22 pm »
When my amp is just sitting there the reverb crashes ever so slightly, not loud or anything.  There is no vibrations?  Any thoughts?  Thanks!
Chris
Offline rafe
  • I have tube amps
Re: reverb self crashing
« Reply #1 on: September 01, 2010, 12:56:01 pm »
Do you live in California? Earthquake? Mine has done that on a wood framed floor that wasn't stiff enough
when I'd get to moving about the reverb would crash...... :grin:
Rafe
Offline phsyconoodler
« Reply #2 on: September 01, 2010, 01:43:56 pm »
Microphonic tube.
Offline Searing
« Reply #3 on: September 01, 2010, 05:59:43 pm »
No earthquakes, although it is on a hardwood floor.
I replaced the tubes and tapped on them, did not seem microphonic, the reverb still crashed.  Tubes was my first thought.  Perhaps there is something going on in the tube that is causing this?  I will swap even more to compare.
« Reply #4 on: September 01, 2010, 06:03:14 pm »
Did you check the reverb springs in the tank?If they are flopping loosely they will crash a lot.How old is the tank?
  Also,is it in a bag and does it have a cardboard shield on the bottom?If it's just sitting in the cabinet with no bag or cardboard it will be set off by the vibrations on the floor.
 Try lifting if off the floor on a piece of carpet or a chair and see what happens.
« Last Edit: September 01, 2010, 06:05:25 pm by phsyconoodler »
Offline tubesornothing
« Reply #5 on: September 01, 2010, 11:59:57 pm »
Tape cardboard to the bottom.  Put a strip of 1/2" thick weather stripping on the top.  Put it loosley in a tank bag. Screw it down through the bag, but not through the tank.
Offline RicharD
    • Toxic Water
« Reply #6 on: September 02, 2010, 12:46:50 am »
Could it be a little static pop/crackle on the input side?  I knew an old Fender that for the first 5 minutes it was on, the reverb made some fairly serious noise.  Once it got hot, it stopped.  Never could find the problem.  I think it might have been the infamous conductive fish paper.  Only the shadow knows.
Offline Dave
« Reply #7 on: September 02, 2010, 09:50:03 am »
Yeah, if the plate load resistor is crackling on the 12AT7 (or whatever else might be causing it to crackle) that would cause the reverb to "crash".
Dave
