September 08, 2026, 11:25:02 am
Hoffman Amps Forum image Author Topic: What can I do w 2 single coil pick ups and a 5 way switch??  (Read 7276 times)
Offline TerryD
« on: September 01, 2010, 09:42:12 pm »
I got me an Indonesian Strat that I am going to route out and  put two airline pick ups in.  The airline are humbucker sized single coils.  I'm routing the strat and will have a H H pickguard in place.
What fun can I have with the five way switch and two single coils?
« Last Edit: September 01, 2010, 09:44:50 pm by TerryD »
Offline G._Hoffman
Re: What can I do w 2 single coil pick ups and a 5 way switch??
« Reply #1 on: September 01, 2010, 10:49:17 pm »
Depends on the Switch.  Not much, with a standard Strat switch.  I'm afraid the way they work, there isn't much you can do with two single coils.  The problem is, the standard 5-way strat switch is just a dp3t switch (the same as a Tele) with two extra stops.  The only thing it can really do is the Strat thing.  You can add a coil tap, but that's about it.
IF you get yourself a Super Switch (a 4 pole/5 throw switch), you can do just about anything - series, parallel, out-of-phase - whatever.  You could also go with a dp4t Tele switch you could have both parallel and series options (the instructions should be included with the switch).
Gabriel
Offline TerryD
« Reply #2 on: September 02, 2010, 07:49:27 am »
Thanks!
