September 15, 2026, 07:53:03 am
Hoffman Amps Forum image Author Topic: Seymour Duncan PITA  (Read 5372 times)
Seymour Duncan PITA
« on: September 03, 2010, 09:28:04 pm »
For all pratical purposes i am finished rebuilding this amplifier. I have a real strange problem. (nothing new)
I built this using the Steve Luckey 2204/Plexi schematic using a 470k resistor to A/B the channels / I had to make changes from my original want
Both channels work but the treble pot is wacked. If i turn the treble all the way back the amp gets very loud in comparison to it's volume at full treble pot setting CW
It would seem i have something wired backwards in the EQ but this is a pretty elementary wire up
The blue cap next to the Sozo .68 is not hooked up yet (just laying there)
Anyway i had to put it away for tonight. This amp has kicked me but i got what i wanted done / Always something
This PT is the size of a small dog! The OT isnt far behind
« Last Edit: September 04, 2010, 07:04:07 pm by plexi50 »
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
Re: Seymour Duncan PITA
« Reply #1 on: September 03, 2010, 09:44:08 pm »
Is that 5U4?  That one will get a workout. I think it's rated at 1000mA but It'll sag 40v at ~200mA.... I'd imagine it'll drop quite a bit in that unit.
Neat build anyway!  :grin:
j.
Open Minded But Fixed Bias
« Reply #2 on: September 03, 2010, 09:59:18 pm »
Well to be honest i think i am going to have to change the PT for a more sane voltage. It is on my variac at 107 VAC and the B+ is 485. I dont want an amp with a 575+ B+. I dont know that i want to try and tame this PT. I want a ballsy amp but not an AMPEG SVT if you know what i mean. Im using a 50uf/500V can cap for the standby and choke which is a 500 ohm resistor for now until the choke i ordered gets here. I have a SS rectifier plug i made to use in place of the tube but thats out of the question with this PT. If anyone has any ideas to tame this PT i will give it one more shot. Otherwise it would be less painful to just to get a JCM 800 PT. Using the 5U4GB sort of freaks me out thinking that it is holding up at all
« Last Edit: September 04, 2010, 09:33:26 am by plexi50 »
« Reply #3 on: September 04, 2010, 02:55:40 am »
another possibility would be to do away with the tube recto, go SS recto and use a pair 6550's or KT88 tubes.
« Reply #4 on: September 04, 2010, 01:10:49 pm »
Will using 6550/KT88 tubes draw the B+ down for me? The PT secondary HV is 415 VAC into the rectifier
